Hi Dan,
Could you answer this question? I am curious as well what kind of spacer is needed to fit.
What size tire is the largest that could fit in front with just spacers? And how much spacing is needed?
Thanks,
John
Hi Dan,
Thanks,
John
I ran a 25 mil spacer to clear z32 brakes. On these rims I ran a 245/40 up front with no problems what so ever. You could easily run a 255/40.
In the rear I ran a 255/40 with no fender or modification. If I use these for track wheels I’ll rock a 275/40 in the rear and a 255/40 in the front on stock body
so the pic you have on there is with a 25mm spacer in front for the s14?
Yeah, in that pic the effective offset is 17x9 +10 with almost no negative camber and a 245/40 Dunlop Sport
Bumpity bump.
