the code is pictured above…i looked it up…its a L3 trans (stock jdm zc trans which is identical to the usdm si trans)
bump
this used to be mine…it out of a 91 crx si its an L3 tranny has shorter gears , meant for a d16a6, but works awesome with a dohc zc…when i bought it off ebay i was told it has less than 100k on it, and i came from a 100% feedback seller… honestly tho man if u plan on keepin that crx for awhile i would keep that tranny and clutch just in case…did u ever get a new clutch or throwout bearing in it? isnt it loud as hell by now?
it still makes noises every once in a while…im in the process of building a lsvtec motor for the crx so all that this clutch needs to last me is another year or so
bump 100 for trans
ttt…nobody needs a d series trans?
