all of my 240sx parts must go, moving on!
FIRST OFF everything is first come first serve
this is a liquidation sale make me offers and buy the stuff!
So I had a bunch of threads and I just merged everything into 1 because I don’t go on son anymore and its just easier for me and you to check 1 thread!
I’ve been playing with 240sx for 5 years and I’m just over it now.
Over the past 5 years I have accumulated a ton of parts from parting out over 10 cars as well as the various cars I’ve built and tons of jdm parts I’ve purchased
I’m looking to liquidate all my parts and possible my drift s14 but for now this is all the spare parts I currently have:
-hks type s s14 fmic kit $500
-jdm silvia front 4 lug spindles with silvia calipers, rotors and pads $160
-jdm s13 tc rod brackets $60
-s13 sr20 sidemount setup(does not include blitz bov) $200
-blitz blow off valve with hotpipe $140
-greddy profec electronic boost controller $180
-s13 silvia coolant overflow tank $30
-s13 silvia windshield washer reservoir with motor and brackets and wiring pig tail $40
-hks intake kit $80
-s13 upper rad support $80
  • complete jdm sr20 air conditioning setup $160
    -oem sr20 flywheel $60
    -oem sr20 engine mounts same thing as ka but low mileage and great shape $60
    -oem 370cc sr20 injectors perfect for ka turbo $100 shipped worked flawlessly
    -s13 sr20 blitz tuned ecu $350 o.b.o
    -sr20 lightweight aftermarket flywheel way lighter than stock $200
    -sr20 clutch fan and shroud (your car wont overheat again) $80
-s14 sr knock sensor $40
-sr20 starter motor $100
-sr20 alternator $100
-sr20 flywheel $60
-coilpacks $80
-s14 sr lower wiring harness cut but usefull for the plugs for sr20 swap $20
-CA18DET igniter chip(can be used with sr20 aswell) $20
-CA18DET SMIC setup minus upper hotpipe $100
-CA18DET MAF sensor $50
-CA18DET rubber intake tube $40
-ka24de flywheel $50
-ka24de engine mounts $60
-ka24de coil and chip $20
-ka24de mafs $40
-ka24de shifter assembly $10
-ka24de downpipe $20
-KA24DE a/c e-fan $20
-rb20det coil pack cover $20
-rb20det Alternator $100
-rb20det Starter motor $100
-silvia front end parts:
-headlights $200
-corner lights $100
-bumper support $60
-headlight brackets $80
-fenders $300
-hood $260
-GTR grill $120
-rear non hicas subframe of a 93 coupe with lower control arms swaybar $80
-180sx center rear taillight garnish $40
-jdm front lower control arms $40 each
-charcoal 240sx hatchback under tail light panel no rust $40
-z32 fuel filter $10
-s13 catback APEXi N1 EVO mint shape $500
-black s13 driver mirror $20
-black s13 gas tank door cover $20
-s13 passenger window switch and plastic $10
-dohc s13 power steering reservoir $20
-both rear s13 spring/shock assemblies $50
-rear trunk(COUPE) with spoiler no rust $60
-s13 fuel pump $40
-s13 front cross member $80
-s13 washer fluid tank with pump $40
-s13 axles $40
-Manual S13 ka Speedo Sensor $40
-s13 left and right traction rods $20 each
-s14 rear lower control arms $40 each
-s14 rear traction arms $20 each
-s14 rear upper control arms $20 each
-rear s14 jdm calipers with ebrake cables and pads $120
-s14 power steering overflow $40
-s14 coolant overflow $40
-s14 zenki taillights $40
-s14 front cross member $80
-s14 passenger airbag with control module $100
-s14 LE rear swaybar $60
-s14 zenki grill $20
-2 r33 gtr wheels $400 17 x 9 +30 offset
i have even more parts so if you need something do not hesitate for 1 second to pm me because there is a very good chance i got it
also i can ship anything
and the best way to contact me is via private message or if you already know me feel free to call me
here are pics of some of the stuff
http://i45.photobucket.com/albums/f94/sir_driftalot/silvia1.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/silvia2.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/fender2.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/fender1.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/lights.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/hood.jpg
http://img441.imageshack.us/img441/9995/img1910pu3.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/IMG_3195.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/IMG_3196.jpg
http://img505.imageshack.us/img505/1694/img1926li0.jpg
http://img401.imageshack.us/img401/4256/parkedkv2.jpg
http://img238.imageshack.us/img238/4625/sideviewyq1.jpg
http://img136.imageshack.us/img136/4065/img3046fs0.jpg
http://img219.imageshack.us/img219/8641/img3047gk4.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/IMG_3192.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/IMG_3191.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/IMG_3190.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/IMG_3188.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/IMG_3187.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/greddyprofecboostcontroller.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/boostcontroller2.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/coolantoverflow.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/apexiairsuctionkit.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/SMIC.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/silviawashertank.jpg
http://i45.photobucket.com/albums/f94/sir_driftalot/tcrodbrackets.jpg
http://img113.imageshack.us/img113/8663/blitzbp5.jpg
bump
s13 front jdm spindles complete with hubs $40 each or $60 for pair
have a tranny mount?
i don’t think he’s been on lately… i sent him a PM about a part or two like 4 days ago, still no response… :confused:
any 5spd parts at all?
the moutn itself or the metal bracket? i think i have the bracket maybe ill check
what part?
I got a ka flywheel I’m pretty sure.
silvia fenders SOLD
Access ECU… i’ll resend the pm if you want.
Dan.
(No Edit)
Also forgot, but would you happen to have any FMIC piping for an S13, or front/rear strut tower bars?
yea resend the pm i never got it
i have no STB’s for sale at this moment
and i have a complete s14 sr20 fmic kit (HKS type S) used but in great shape
usdm s13 axles ?
edit: sold
Hey s13 hows the search for mount goin?
cant find it sorry man!
EVERYTHING IS NOW BEST OFFER TAKES IT!
Avery, do you still have that coupe version select rear bumper?
sorry dude it sold
how much for the greddy profec?
Do you have a driver door glass (window)? If so how good of a condition is it in? Any scratches? And how much? Plz pm me.
PM’d. plz call me asap
