I’ve gone over all my threads since a lot of the parts have been sold and this is my new single thread with all parts that i currently have for sale!
-s13 passenger door $60
-s13 wingless hatch great shape $200
-sparco racing wheel got a rip in the suede $30
-sr20 oem flywheel $60
-s13 front cross member $60
-s13 silvia windshield washer reservoir small! will fit with FMIC with pump $40
-s13 coolant overflow tank $30
-s13 cluster surround $20
-s13/s14 Front strut bar $40
-1993 q45 2 piston front brake calipers with new front slotted rotors and PBR pads $220
-rear calipers with slotted rotors and PBR pads $160
-4 lug hubs with extended wheel studs all 4 corners $100
-hicas rear swaybar with endlinks and bushings $40
-tail light set with blacked out center $40
-1991+ gauge cluster $60
-s13 Privacy Cover $20
-s13 OEM sr20det injectors 370cc $80
-stock rear s13 shocks with springs complete $60
-jdm s14 front shocks with springs complete $60
-Greddy 52mm gauge pod for a gtr but it works good on s13 too $60
-s14 sr20 IACV valve $40
-s14 power steering reservoir $40
-s13 left and right axles $80
-s13 rear lower control arms $40 each
-KA starter motor $60
-KA oem injectors $60
-KA Fuel Rail $40
-s13 KA valve cover $40
-s13 KA oem cams $80
-KA alternator $60
-s13 sr20 OEM rubber intake pipe $40
-2 JDM 5 bolt VLSD’s compelte in pumpkin one has s13 rear cover the other has s14 rear cover $60 each
-s13 RHD shifter surround plastic with boot $20
-KA flywheel $50
-silvia s13 front spindles complete with hub upright and calipers rotors and pads $120
-OEM s13 fuelpump $20
-s13 diff cover $40
-s13 brake booster $20
-s13/s14 oem engine mounts good shape $50 a pair
-s13 SOHC mafs $50
-s13 DOHC mafs $50
-pair of ichiba 20mm slip on hubcentric spacers 5 x 114.3 $80
-pair of H&R 15mm slip on hubcentric spacers 5 x 114.3 $80
-ebay/bings Chrome Greddy intake manifold brand new but was mounted to a engine that never ran $200
-sr20 alternator $80
-s14 srt20 throttle body $40
-s13 ka24de throttle body $40
-ca18det smic with cold pipe $60
-RB20 starter motor $60
-s13 steering column with key $80
-HKS style BOV $80
-s14 green zenki oem grill $20
-s13 undertail light piece grey $40
-s14 oem TC rods $40
-s13/s14 2.25 (oem size) highflow cat flanged for s13/s14 used for 4,000 km’s (WILL PASS EMISSIONS WITH THIS FOR SURE) $80
all parts are located 401/islington area GTA
please PM me for Phone number or to arrange pickup/meetup
thanks for looking
