cluster is SOLD
i got the pump
and let me double check the surround
cluster is SOLD
i got the pump
rb 2o starter works on rb25?
hmmm I’m not sure. you can try it out and see if it works if you like
-pair of ichiba 20mm slip on hubcentric spacers 5 x 114.3 $80
-pair of H&R 15mm slip on hubcentric spacers 5 x 114.3 $80
BOTH SOLD
s13 hatch SOLD
Do you have a S13 Driveshaft?
Check Pm’s
SOHC mafs SOLD
passenger door SOLD
BUMP
do u have the stock Front Tension Control Arms. If so i am interestred
Do you have, s13 left rear caliper?
check your pm’s
not currently
i have front tc rods for s14, not s13 currently
Pm’s replied!
Updated list of whats still available
-sparco racing wheel got a rip in the suede $30
-sr20 oem flywheel $60
-s13 front cross member $60
-s13 silvia windshield washer reservoir small! will fit with FMIC with pump $40
-s13 coolant overflow tank $30
-s13 cluster surround $20
-s13/s14 Front strut bar $40
-240sx hatch blacked out center tail light $20
-s13 Privacy Cover $20
-s13 OEM sr20det injectors 370cc $80
-stock rear s13 shocks with springs complete $60
-jdm s14 front shocks with springs complete $60
-Greddy 52mm A pillar gauge pod for a gtr but it works good on s13 too $60
-s14 sr20 IACV valve $40
-s14 power steering reservoir $40
-s13 left and right axles $80
-s13 rear lower control arms $40 each
-s13 sr20 OEM rubber intake pipe $40
-2 JDM 5 bolt VLSD’s compelte in pumpkin one has s13 rear cover the other has s14 rear cover $60 each
-s13 RHD shifter surround plastic with boot $20
-KA flywheel $50
-OEM s13 fuelpump $20
-s13 diff cover $40
-s13 brake booster $20
-s13/s14 oem engine mounts good shape $50 a pair
-s13 DOHC mafs $50
-ebay/bings Chrome Greddy intake manifold brand new but was mounted to a engine that never ran $200
-sr20 alternator $80
-s14 srt20 throttle body $40
-ca18det smic with cold pipe $40
-RB20 starter motor $60
-s13 steering column with key $80
-HKS style BOV with aluminum hotpipe $120
-s14 green zenki oem grill $20
-s13 undertail light piece grey $40
-s14 oem TC rods $40 for both
-s13/s14 2.25 (oem size) highflow cat flanged for s13/s14 used for 4,000 km’s (WILL PASS EMISSIONS WITH THIS FOR SURE) $80
i need the SR20 Flywheel!!!
let me know
Junior
hay wats ur # wouldnt mind to come have a look tomorrow sunday at ur goodies
pm me thanks im a couple blocks away from u
intake pipe and cat SOLD
UPDATED PARTS LIST
-KA flywheel $50
-s13 diff cover $40
-s13 DOHC mafs $50
where ru located exactly?
401/islignton
bump
