S14 STUFF
-s14 rear lower control arms $40 each
-s14 rear traction arms $20 each
-s14 rear upper control arms $20 each
-rear s14 jdm calipers with ebrake cables and pads $120
-s14 mirrors $60 each
-s14 power steering overflow $40
-s14 coolant overflow $40
-s14 zenki taillights $40
-s14 front cross member $80
-s14 passenger airbag with control module $100
-s14 LE rear swaybar $60
-zenki grill $20
-climate control $40
IF THERE IS ANY S14 PARTS YOU NEED THAT ARE NOT LISTED HERE PLEASE PM ME
SKYLINE PARTS
complete front r33 brakes
normal z32 are 280 x 30 rotor r33 are 296 x 30 wooot also teh caliper is much larger to dissipate heat
$300
S13 STUFF
-rear non hicas subframe of a 93 coupe with lower control arms swaybar $80
-180sx center rear taillight garnish $40
-jdm front lower control arms $40 each
-jdm 4 lug front spindles with good bearings $50 each
-jdm rear 4 lug hubs with good bearings $40 each
-charcoal 240sx hatchback under tail light panel new paint no rust $40
-z32 fuel filter $10
-catback APEXi N1 EVO mint shape $500
-black driver mirror $20
-black gas tank door cover $20
-s13 passenger window switch and plastic $10
-tail lights $10 each
-power steering reservoir $20
-front abs rotors $20
-both rear spring/shock assemblies $50
-rear trunk(COUPE) with spoiler no rust $60
-fuel pump $40
-front cross member $80
-washer fluid tank with pump $40
-s13 axles $40
-cluster surround $40
-Manual S13 ka Speedo Sensor $40
-RHD NON abs brake master cyl excellent for upgraded turbo as the lines come out on the other side $20
-left and right traction rods $20 each
-left and right rear upper control arms $20 each
RB PARTS
-rb20det coil pack cover $20
-rb20det engine mounts $50
-Alternator $100
-Starter motor $100
WHEELS
Nissan SKYLINE R33 GTR (2 wheels no rubber)
wheel spec:
size 17" x 9" +30
bolt pattern 5 x 114.3
PRICE $450
KA24DE/KA24E PARTS
-ka24de flywheel $50
-ka24de engine mounts $60
-ka24de coil and chip $20
-ka24de mafs $40
-ka24de shifter assembly $10
-ka24de downpipe $20
-KA24DE a/c e-fan $20
CA18DET PARTS
-CA18DET igniter chip(can be used with sr20 aswell) $20
-CA18DET SMIC setup minus upper hotpipe $100
-CA18DET MAF sensor $50
-CA18DET rubber intake tube $40
s14 sr20 PARTS
hey guys i have a s14 sr20 that was damaged in the container during shipping so I’m parting it down.
here are some pics of items i have for sale:
here is price list of items in pics:
-s14 sr knock sensor $40
-sr20 starter motor $100
-sr20 alternator $100
-sr20 flywheel $60
-coilpacks $80
-s14 sr lower wiring harness cut but usefull for the plugs for sr20 swap $20
pm me
