FS: lot of s13 parts, body, engine, audio, *updated*
hey guys i have alot of stuff lying around i want to get rid of so please help me out im letting this stuff go
-stock s13 rear struts unknown (2 for 20$)
-stock s13 springs on s13 struts with mounts whole assembly drop in 60$)
-stock s13 rear springs unknown (2 for 20$)
-90’ S13 front hubs with control arms, steering ball joints, calipers, good rotors and KVR pads (both left and right for 150$)
-180sx front sway bar no rust 100$
-180sx front sway bar end links mint 50$ each fresh virgin ball joints
-180sx tc rods with not-leaked-out bushings 100$ both
-180sx engine crossmember, no rust, mint 50$
-180sx engine crossmember mounting bolt brackets MINT 20$ both
-180sx brake master and pedal assembly 50$
-180sx clutch master and pedal assembly 50$
-180sx powersteering rack RHD (mintest condition everything) 50$
-180sx steering column with jdm nissan key 20$
-180sx sr20det AC setup 200$ mint
-180sx firewall insulation 20$
-180sx front clip carpet CUT at front seats, black 50$
-KA24E PS pump 20$
-KA24E PS reservoir 20$
-KA24E Head 30$ (send camshaft to pdm and get it machiend ftw)
-KA24E valve cover 30$ cleaned out inside in varsol
-KA24E oil pan (ready for ka-t bung welding) cleaned out in varsol
-KA24E intake pipe, airbox, resonator box, and tubing 20$
-KA24E radiator 50$
-KA24E intake manifold and throttle body 20$
-KA24E downpipe 20$
-KA24E exhaust manifold 20$
-KA24E AC compressor 20$
-KA24E water pump 10$
-KA24E rad shroud 20$
-KA24E manual ECU 30$
-s13 zenki foglights 30$
-s13 zenki white bumper scuffed and tired 20$
-s13 zenki black bumper in ok condition 50$
-s13 zenki rebar 50$ mint
-s13 zenki turning lights 20$ both
-fastback hood white sprayed 50$
-fastback sohc cluster 30$
-fast cluster surround 30$
-steering column piece with turning signals and viper controls 30$
-mudflaps 5$ each
-fliplight covers sprayed white 25$ both
-complete flightlight assemblies plug and play 80$ both
-tweed door skins 35$ both
-tweed glove box 20$
-zebra 180sx glove box 20$ missing handle
-wheel well covers 20$ for both
-interior black pieces beside rear seat, fastback, $35 both
-stock 4x6 speakers clarion 20$ for both
-S13 fusebox 10$
-S13 interior fuse box 10$
-S13 relay box 10$
-S13 non abs driveshaft 30$
-random lower and interio harness connectors 5$ each
-hatch interior plastic panels for speakers 20$ both
-hatch interior metal brackets 20$ both
-hood support stand 10$
-180sx stripped front clip mint frame rails 100$
-240SX stock muffler bought at CT used for 1 year 50$
-pioneer 6x9 speakers paper cone 50$ mint
-sony xs L121p5 1200watt subwoofers, I have a pair, bought new, 50$ each
-complete KA24E with uncut harness, mafs, egr assembly, all vacum lines hooked up, downpipe, intake pipe, replaced timing chain and guides assembly, replaced injectors, 262000KM, burns a little oil, 200$.
-pirelli P6000 not that much thread 235/60/16 i have a pair 20$
-RHD dash 20$
-4 monroe s13 non-abs front brake pads 80% thread $ 40
-4 kvr pdm-racing s13 non-abs front brake pads 60% thread $ 60
-s14 rear and front springs 20$ per pair
-s14 unknown front shocks 10$
-s13 front rotors non-abs 30$
hey man ill take that white good off ur hands if you could keep it for a week and a half
i’ll take the front wheel covers as well as the front carpets…pm with your contact info…
hey,
ill take that KA24E oil pan, mines got a huge assed crack in it.
PM me, im in NB
Thanks
Rob
is that rebar for the s14??
does the rad work for ka24De?
thanks
ill take that fender for $20 if there is no dents just scuffs… is there rust?
are you going to dereks track day by chance?
jesse i pm’d you
i was wondering where are these parts located?
aurora/richmond hill, i am willing to meet up in richmond hill if its next week
do you have a hatch by any chance?
sorry no, theres one on the island, nutta knows, lol jk, no hatch here… wtb white hatch btw…
I could not make it out if you had carpet for sale( looking for carpet for a hatch) Very interested, let me know ASAP. Thanks.
CVM07
i have carpet from a clip (up to front seats), its good for a gutted race car, so you have carpet where you feet go, the rear seats wouldnt have carpet, this carpet is black, not grey, and more or less mint…
bump for list edited for parts…
whats the condition on ka radiator?
its fine, i jsut pulled it out, fins are ok, no dents, cracks or anything, didnt leak, worked perfectly fine
I also have:
I also have:
What’s the condition on your exhaust manifold? Is the exhaust downpipe another part I’d need for replacing everything the entire exhaust system from the manifold all the way back? I so, is the downpipe good too?
