FS: 2002 camaro SS partout, LS1 and 4th gen camaro/firebird parts LME 402, t56
O2 extension harnesses, 36inch extra long. $10 each
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/IMG_2045.jpg
LS1 fuel rails $30, and AC belt $10 (GM PN 12569529) Like new only 20K miles on them.
Mint 98+ camaro washer bottle, clean no damage. With pump, works great. $30
ABS module, braket, and brake lines. No damage works great, off a LS1 car. $40 obo
passenger side airbag with mount, and ABS control module. $150 obo
cat $6
OK, this may not be the most organized car part out, so read everything. These parts are off a friend/customers 2002 camaro SS, that sadly was in a bad wreck. To help him the new era guys, and a lot of others are helping out here. But there is a compromised of time/money spend on removing/cleaning/inspecting/listing/selling parts. And the money raised doing it, in a already full day of working on customers cars.
All these parts are SOLD AS IS, and its encouraged to stop up at the shop and check them out yourself, and make a offer. That is how alot of this stuff is selling. Many parts with light damage were bought dirt cheap, because they know they could easily fix them. Show cash, don’t lowball thats all were tring to do really.
I also have the right to raise the prices, I few parts I been sold without knowing there real valve. I’m not looking to rip anyone off, but this stuff really can’t be given away. The money really needed, and a few parts have been sold fir way less them there worth becuse we didnt have tim to look up, if ther hard to find/ unavavilbe anymore. sucth as the SS spolier with brake light, other SS/SLP parts.
Stock motor mounts- SOLD
LS1 fuel/Evap line. Clean. Replace you ugly old, damaged, or for a motor swap. $30
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/IMG_1818.jpg
ASR switch- SOLD
SS 10spoke wheels, with tires. Not in flawlass shape, they are dirty $125 each
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS018.jpg
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS019.jpg
SOM SS sail panel. Perfect for berger mod, has a crack but not seen under the passenger tail light. The passenger end is a little twisted but might be fine once bolted to a car. The car had a little damage on the side, but it is flexable. $25
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS004.jpg
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS002.jpg
ARP Hex Head Bolt Kit head bolts, Like new only 2-300miles on them $75. They are $100 new.
For LS2, L92, LS7, and mid-year 2004+
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS003-1.jpg
Powerbond 25% Underdrive crank pulley for LS1 Fbodys- SOLD
Driver side LS1 caliper, with caliper bracket, all bolts, good pads, and flex line. $25
trunk carpet, (has a tear in pic, the weather stripping should hold it down and you wouldn’t notice it) $25
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS003.jpg
I also have another spare one with a tear form the latch spring $20
driver side rear truck carpet $10
Driver side LS1tail light $50
http://i245.photobucket.com/albums/gg76/Camaro_94/02SS003.jpg
LS1 rear coil springs SOLD
stock toque arms Boxed LS1 M6s, and lighter a4 and v6, $25 each
Driver side Ttops
http://i245.photobucket.com/albums/gg76/Camaro_94/02SS005.jpg
SS floor mats SOLD
SS hatch mat make offer
Dash pad $75
http://i245.photobucket.com/albums/gg76/Camaro_94/02SS008.jpg
driver side mirror (SOM) $75
http://i245.photobucket.com/albums/gg76/Camaro_94/pics08123.jpg
4th gen full carpet. This has all the backing jute, and rubber/tar section removed for weight savings. It still has some area you can cut out to save even more weight. The ears over the rear wheel wells, under the concel, front seats, door sills, and few other places. Its tan is color, but I started to do a color change to the dark grey/graphite. with carpet dye, it works awesome but I haven’t finished it yet. $45 make offer
4th trunk carpet, has a small rip near the hatch lock. $15
RAM power grip HD pressure plate. (do not have the disk) $150
RAM steel billet flywheel $175
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS015.jpg
Ttop holder $20
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS008.jpg
Leather rear seat, dirty needs to be cleaned. passenger lower cushion appears to have a mark form other parts sitting on it. I don’t think its ripping. $100
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS007.jpg
Door jam sill plates $25
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS006.jpg
driver door panel. Im not sure if anything is damaged? make offer?
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS005.jpg
driver door, SOM I didn’t remove it and dont know much about it. But it was pulled off the car, and put with good parts, the driver side was fine I belive. So check it out in person if your needing a door.
LS1 coils, and bracket
this is the 99+ bracket, so if you switch to 99+ heads or aftermarket heads. On you 97-98 LS1 car you need these. Bracket can be bent back. Has the coil harness, one coil is damaged. The other bracket with coils I think someone already bought, so we don’t have a set. $50 ( I’ve heard form customers that coils are over $100 each new)
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS014.jpg
T56 6speed trans. Stock, 60k miles. Was fine before the accident, but the input shaft visually has a slight runout. I didn’t put a indicator on it, but only like .020 at the bushing end. The input shaft bearing is still tight with no/little forced wiggle. Sold as is. Last year t56rebuilds/sixspeeds gave me $500 for a t56 in 3 boxes, with 2 bad gears, and a broken fork.
Make offer over $750, if shipped buyer pays cost.
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS020.jpg
402- SOLD
10bolt, with brakes and everything… I think it has gears…Ill get more info later
One of the many group pics. I have to look thu and see whats stuff worth. feel free to make a offer.
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS011.jpg
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS010.jpg
http://i2.photobucket.com/albums/y11/studderin/shit%20FS/02SS012.jpg
L76 intake manifold is Sold
fuel rails are sold
That master is mcleod. They have been on national backorder all year, and impossable to get.
New go for about $325-$350 Need to get $250 for it.
K&N need to be cleaned, will clean like new. $25
QTP 3inch cutout, everything: wiring, switch, motor, part of stock Ipipe $100. Is far as I know it works, but hasn’t been tested. As with everything else it encouraged to check out the parts yourself and test them. Will probably cut down the Ipipe if need to ship, at buyer expense of actual shipping cost.
stock MAF $50
Tons of other parts, Ill try to get pics, and a better list.
Pics/details on the SS floor mats?
I just replaced my bump stops in the rear 2 weeks ago and found out THEY DO NOT MAKE THESE ANYMORE. if you want some you have to get a different style and modify them so if anyone needs a set you should buy these, it will make your life easier and won’t cost as much.
What kind of tires are on the rims? Might be good wheels for the track…
also more info if 9c1ny isnt intrested
list some more parts please too, theres a few things i maybe looking for
thanks TORQDSS, I didn’t know that.
These are just some parts I’m listing for a friend, in some sad times with medial cost and such. So I can’t really be giving this stuff away hooking people up. I was pulling parts of the car till after dark lastnight. I need to get pics, and find out more pricing on other stuff. thanks.
floor mats are sold pending payment.
thanks
i know you said nothing about this and prob dont have it, but its worth asking. Do you have the power antenna assembly at all for sale?
Maybe, we’ll take a look at the car. John thinks it does have it…
I posted about the floormats 2 fucking hours after you made the post and they’re sold before I can even get info or a price???
ya, alot of the big parts people saw at the shop and bought them that way. The drivetrain and such.
i might take some of these things…
is that caliper front or rear btw?
front. I’ll have to look at the rear, their off the car with the 10bolt, TA… I’m going to diffrent brakes and might have mine to, but I think there called for allready.
gimme the shortblock!!! :tup:
SLP rear jouse bumpers, sold today.
Pat, the shortblock is bad ass, but the starter tab is cracked and needs to be rewelded. gen4 402, new LS2 block, compstar rods, custom wisco flat tops with L92 relives -8cc I believe. Build by LME has very low miles $1,500. Car took a good hit, selling cheap with no warranty, you should check everything.
added lightweight tan carpet.
and another trunk carpet with a rip near the hatch latch
i’ll let ya know on the shorty. thats a wicked price and i’d love to snag it up. any pictures of said shortblock? feel free to pm to me or whatnot.
ya just the rotating assembly is over $2,500 But with the unkown damage its hard to find a price, or offset the time to look into it. So just gona sell it AS IS for best offer really. A local offerd 1,300 but not sure if Mike wnat to sell it that cheap. I’d buy it just got the parts for that price, and make a LS1 coffe table. I’ll see about pics, I was busy working on the car outside till after dark, and didnt get any. I think the shop camra has some pics on it. Shawn can probably post them up mon.
your cars a m6 just pop start it everytime. :slight_smile:
added more parts, removed parts that have sold
SS mats
SLp jose bumpers.
