Just got a set of new wheels and tires so these need to go. I bought them off of Mr. T on here not long ago. Since then I tried to sand most of the curbage off of them and I painted them flat black. The rear tires are 245-45-17 and the fronts are 225’s if I recall. Fronts have some camber wear and the rears only have a hanful of heaters. When we replaced the tires we noticed the one rear rim has a crack in the center of it…it does slowly leak air and should be repaired at some point. I’d like $250 for them. Lug pattern is 5x114.3. Thanks.
