Yes, it’s happening. Don’t question it. Just send me your money.
Prefer local sales but, may be willing to ship IF YOU PAY SHIPPING. WHICH IS EXTRA.
MORE ITEMS WILL BE ADDED. PICTURES OF PARTS AS THEY COME OFF THE TRUCK WILL BE ADDED.
I WILL SHIP MOST PARTS. USUALLY CANADA POST / USPS.
I HAVE PAYPAL. WILL ACCEPT CASH AND EMT ALSO.
Complete build thread is on here.
Exterior:
Edge “Power dome” hood - $SOLD
Fibreglass Tonneau = $SOLD
17x8 98 Mustang Wheels - $SOLD
Passenger fender rusty - $SOLD
Passenger door $SOLD
Stepside tailgate. SOLD!!
Front bumper - $SOLD
Rear bumper - GONE, see fibreglass pan
vent visors for doors - $SOLD
Drivers fender is good, $20. No inner
Drivers door is rough (rusty) on bottom. $20
XLT mirrors. Power. One side was cracked and reglued. - $30/pair
Black stepside box - Has some scratches, rusted metal under fibreglass but, glass isn’t cracked. Comes with Fleetside rollpan cut to fit and tail lights - $200.
3x 16" Grand Marquis meshies. I know the 4th one is at the yard still or where to find more. $140 (what I paid). Hard to find.
solid rear glass with nice reflective factory tint - $40
Headlights - $10/light (corners/heads)
Tail lights … go with bed.
wiper arms - $5/ea
front glass… if it can be saved - $50
grille - $20
header panel - $20
Interior:
Seats - $SOLD
headliner $SOLD
Digital Boost/vac gauge $10
Oil Pressure gauge (small, not standard diameter) - $10
Innovate MTX-L wideband /w sensor - $150
3,0L cluster, works. 192kmish on clock - $25
air bags (i have many) - $10/ea
2.5L cluster, havent tested. Came from Kenny’s - $25
misc interior panels - $5+
Ranger FX4 Level II Floor mats, factory form fitted, clean - $40/pair
Suspension:
4x Bolt on 1.25" spacers SOLD!!
DJM 4/5 kit with new upper Moog “Problem Solvers”, includes shorter end links for sway bar - $250
S10 2" Drop coils (resulting in a 7" total front drop when used with DJM arms) - $50
1999 2wd spindles - $20/side
1999 front calipers - $10/side
brake rotors with newer bearings - $10/side
7.5 OPEN Rear end that’s been WELDED, has newer brakes, ebrake cables and shocks (one seems blown) - $50.
Illusive Fab ver. 2 raised tranny crossmember - $80
1999 reg cab 6’ box steering rack. has bent inner tie rods. - $20
2006 ext cab 6’ box steering rack. one boot needs a clamp/ziptie - $40
Drivetrain:
2.3 LIMA TURRRRBOOOO;
ARP head studs - $SOLD
'96 Ranger block - $SOLD
Mishimoto FMIC - SOLD
TC aluminum valve cover - $SOLD
TurboSmart 38mm WG, $SOLD
2.3L starter - SOLD!!
head, nothing special. OR Cam, rollers, lifters. - $50
98+ 2.5 Harness thinned out - $40
98+ 2.5 Harness not thinned but, auto - $40
98+ 2.5L block side engine mounts - $40/pair
XR4Ti internals, ARP rod bolts. $120
Large T3 off an older inline 5 Volvo .60/.63 with downpipe full 3" - $200
3" Magnaflow high flow cat - $50
custom 4" square tube upper intake /w 65mm Non-IAC Mustang TB - I have over $400 into this. will take $150.
Synapse Syncronic BOV, works well but, the set screw holes have ovaled. i was going to tap for a larger size. will include charge pipe section - $60
– “Stinger” style Top mount manifold, has been rewelded a lot. very strong now. - $75
FLH2 ecu (2.5L 5 speed 98+) $75
TwEECer R/T tuner - $250
DataQ box - $30
blow thru 05+ Ford Slot MAF /w IAT built in will include charge pipe i made for it - $50
42# green top injectors - $100
Taurus E-Fan with sensor controller and manual switch - $40
87 Thunderbird TC WCT5 (hydraulic slave) with S10 tailstock/shift plate/shifter (later model so shorter throw shifter) hydro bell was rewelded ear broke off. new front bearing. - $200
Centerforce Stage 2 clutch for the T5 mated to 87 TC Flywheel. Was a $650 CLUTCH ONLY. Used for maybe 15k? $200.
3.0L driveshaft from 1999 Reg Cab 6’ bed. - $25
2.3L driveshaft from 1996 Reg Cab 6’ bed. - $25
Walbro universal 255lph pump with newer sock installed in 99 Ranger sending unit. - $60
2.5L power steering pump on bracket - $25
3x Ranger/Explorer alternators. - $30/ea
Mazda B2300 Rad - $25
2.3L oil pan drilled n tapped with bung for oil return - $25
MISC:
Aluminum subframe bushings - SOLD
Mishimoto Rad - $SOLD
S13 LCA’s - $50/pair
S13 rear uprights 4 bolt hubs - $20/ea
S14 bare subframe - $40
S13 rear axles 6 bolt - $50/pair
s13 rear brake calipers /w ebrake cables - $20/ea
S13 Coupe tail lights - $30/pair
2x 4 bolt slip on 5mm spacers new. $15/pair
PHOTOBUCKET ALBUM OF PARTS
http://s44.photobucket.com/user/Riddle_Rob/library/RangerSX%20partout
