Contact: PM or Text (647)300-3022
I want EVERYTHING gone. NO PARTING, unless you find me a buyer for all the other stuff.
I just need all of this gone so I can have my garage back. Whatever you see in the pictures is all I have and what you get.
Anyone who’s met me or dealt with me knows I’m an honest person, so here’s the details on all this stuff:
Engine without a valve cover on(There is a valve cover pictured, it’s just not bolted on, the bolts are in the box of bolts): K.man’s old engine, it’s a parts engine full of kms, only thing wrong with it was the Timing Chain Tensioner broke so he had to keep re-timing it. No oil-pan
Engine WITH valve cover on: Prabu’s old engine, I was old ~120,xxx kms, Vacuum leak. Picked it up as a spare in case K.man needed anything cause I’m prepared like that, or at least I try my best to be.
I have a hoist, so I can help you load this in your car no problem.
$150 Fairly firm on it, I just want it all gone so make me an offer I can’t refuse.
Everything is from S14 KADE.
Off the top of my head (in a rush right now, I’ll update later)
-Fan
-Fan shroud
-2 water pumps
-power steering pumps
-AC compressor I believe?
-2 flywheels OEM
-1 OEM clutch w/~120 000 kms was what I was told
-box of bolts from the two engines
-Oil pan already plumbed with -6AN line I think? for you KA-T guys.
-2 thermostats
-1 SET of motor mounts OEM
-2 Alternators
-Oil pick up
-Upper coolant neck…or lower…I forgot. Someone confirm
-Throttle body
-Injectors with lines (whatever is picture there)
-OEM Rear upper control arms (RUCAS) bushings don’t look shot
-OEM Toe arms ,bushings don’t look shot
-some heat shields.
I’m keeping the gold chain on the engine with no valve cover bolted on, so no you can’t have it =P
KA Stuff by wilwmak, on Flickr
GET YUR KA ON.
Thanks!
