This Adjustable-Height 20 in. Oscillating Pedestal Fan is a high-velocity fan that brings powerful cooling to large spaces that require heavy-duty ventilation and air movement. The oscillating pedestal fan is perfect for warehouses, workshops and garages. With 3 speeds and adjustable height, you can adjust the amount of air flowing to ventilate the room accordingly. The fan features circulation of up to 4,800 CFM for powerful cooling. The 9-1/2 ft. grounded cord offers easy positioning.
- 3 speeds allow you to customize the airflow
- Circulates up to 4,800 CFM for powerful cooling
- Oscillation ensures maximum air circulation
- Height-adjustable design gives you greater control over the direction of air circulation
- Pivots for air flow adjustability
- Thermostat lets you adjust the temperature
- Metal housing provides strength and durability
- Designed for indoor work area use
- Energy-saving fan has a low amperage input but high output
- Stand-alone design allows the fan to be firmly positioned on a floor
- 9-1/2 ft. grounded cord for optimum positioning
- High-velocity aluminum die-cast lubricated motor
- Fan Type : Pedestal Fan
[ATTACH=CONFIG]21992[/ATTACH]
One of the best fans I’ve owned. $60
