I’m selling my baby. Here is all the info on it and a picture of it in the link.
Up for sale is my 03 Blazer LS 4X4. It has 329,xxx kms on it, but I have never had one problem with this vehicle at. You will see one for the same price as mine will less kms, but they are all stock, which mine is not. I have put lots of money into this to make it how it is from when I bought it, which it was stock when I bought it.
This vehicle sits 4" higher then a stock one does from the longer rear shackles and the front torsion bars being cracked up and the bigger rims and tires on it.
Here’s a list of the factory options it has:
-A/C (which blows cold)
-Heat (which is nice and hot)
-Keyless entry
-Power windows
-Power steerting
-Auto headlight
-Heated mirrors
-Factory driving/fog lights
-Over head console with outside air temp reading
-4 map lights
-Push button 4X4 (2lo, 4lo, 4high)
-40/60 split rear folding seats
-Tow package good for 5000 LBS of towing
There is a few things it needs to make it perfect, but it’s nothing that will make it not pass a safety with it will the way it is.
The problems are:
-Front axle click when driving from the torsion bar being cranked all the way up. -Front rotors have a vibration to them.
-Engine light is on. It’s a evap code. (does not effect anything)
-ABS light is on from a sensor needing to be replace
-Brake light is on from level sensor in brake reservoir
Here’s a list of everything I have put onto it:
-31x10.5x15" tires
-15x8" steel rims
-1" rear wheel spacers
-Weston front light bar and brackets
-6" driving lights which HID’s installed which are 6000K
-HID head lights which are 6000K
-2" longer rear shackles
-Vent visors
-Bug deflector
-Short arm intake
-Cat back exhaust with Cherry Bomb muffler and Magnoflow tip
-Clarion 5.25" 160 watt front spearker
-Amp kit
-Aftermarket switches for driving lights
-Tinted tail lights
-LED dome light (front and back)
-Full size 31x10.5x15" spare rim and tire
-Aftermarket radio
Maintenance stuff done over the last 6 months:
-New front upper ball joints (both sides)
-New rear brake pads, rotors, and sliders
-New cap and rotor
-Transmission flush (5000 kms ago)
-Oil change every 5000 kms
My price if $4500 OBO. I need it gone.
