2003 Infinity G35 4 door auto
This is a 2003 g35 4 door silver with black leather, all power options work new front brakes, new lca bushings, new compression rod, new rad and water pump.
The BAD!
Engine bleeds air into the cooling system, Headgasket or small crack in the head(s)
basically you drive the car for 4-5 days no issue then all of a sudden you loose heat, re bleed cooling system your good for another little while… no time to fix have to prep racecar for up coming season!
340xxxkm on the clock and still counting car drives amazing, test drives welcome.
will come etested, cert if the price is right.
2600 OBO do not low ball me, I will just keep it and fix in the summer
will post pics soon or send via email.
