QUESTIONS? CALL US NOW!
TOLL FREE NUMBER:
1-877-JDM-0-JDM
1-877-536-0-536
Nissan Motors
~All the engines we have are in good mint working order.
~Compression test has been done.
~All the motor we sell has strong to perfect compressions.
~Each motor is hand picked in Japan and taken out of running cars.
~We can do the compression test and take pictures of it for potential customers upon request.
~PRICES LISTED ARE FOR STORE PICK UP
~WE OFFER SHIPPING ANYWHERE OUTSIDE OF TORONTO/ONTARIO w/ FREIGHT COMPANIES PM FOR SHIPPING CHARGES
~LOCAL DELIVERY ARE AVAILABLE WITHIN GTA, EXTRA GAS CHARGE MAY APPLY OUTSIDE OF GTA
CA18DET Complete engine & transmission $1199.99
ENGINE BLOCK TOP AND BOTTOM
5 SPEED RWD TRANSMISSION
CLUTCH AND FLYWHEEL
PRESSURE PLATE
INTAKE MANIFOLD
EXHAUST MANIFOLD
TURBO
FUEL RAIL
THROTTLE BODY
DISTRIBUTOR
SPARK PLUGS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECTORS
OIL PAN
VALVE COVER
UN-CUT WIRE HARNESSES
MASS AIR FLOW SENSOR
ECU
ACCESSORIES (SENSORS)
S13 SR20DET Red Top $1799.99
S13 SR20DET Black Top Top $2150.00
CLUTCH AND FLYWHEEL
PRESSURE PLATE
INTAKE MANIFOLD
EXHAUST MANIFOLD
TURBO
FUEL RAIL
THROTTLE BODY
DISTRIBUTOR
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECTORS
SPARK PLUGS
OIL PAN
VALVE COVER
WIRE HARNESSES
ECU
ACCESSORIES (STOCK SENSORS)
S14 SR20DET Complete Engine Swap $2350.00
RWD 5 SPEED TRANSMISSION
CLUTCH AND FLYWHEEL
PRESSURE PLATE
INTAKE MANIFOLD
EXHAUST MANIFOLD
TURBO
FUEL RAIL
THROTTLE BODY
DISTRIBUTOR
SPARK PLUGS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECCTORS
OIL PAN
VALVE COVER
IGNITER
ECU
S15 SR20DET Complete Engine $3450.00
only 1 in stock
INCLUDES:
-S15 SR20DET TOP+BOTTOM
-INTAKE MANIFOLD
-TURBO MANIFOLD
-S15 TURBO
-CLEAN VALVE COVER
-6 SPEED HYDRAULIC TRANSMISSION
-THROTTLE BODY
-STOCK FUEL RAIL
-INJECTORS
-SPARK PLUGS
-COIL PACK
-ALTERNATOR
-AC COMPRESSOR
-POWER STEERING PUMP
-OIL PAN
-6 SPEED SHIFTER
-WIRE HARNESS
-ENGINE CONTROL UNIT (ECU)
Avenir SR20DET AWD Automatic $999.99
AUTOMATIC AWD TRANSMISSION
FLYWHEEL
INTAKE MANIFOLD
EXHAUST MANIFOLD
TURBO
FUEL RAIL
THROTTLE BODY
DISTRIBUTOR
SPARK PLUGS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECTORS
OIL PAN
VALVE COVER
IGNITER
ECU
R32 Skyline GTS RB20DET Complete motor swap $1499.99
ENGINE PACKAGE INCLUDES:
ENGINE BLOCK AND HEAD
COMPLETE WIRING HARNESS
CLUTCH AND FLYWHEEL
PRESSURE PLATE
INTAKE MANIFOLD
TURBO MANIFOLD
TURBO
ALTERNATOR
THROTTLE BODY
AC COMPRESSOR
STARTER
INJECTORS
SPARK PLUGS & WIRES
COIL PACK
COOLING FAN
OIL PAN
ECU
STOCK SENSORS
Nissan Skyline RB25DET Complete motor swap $1899.99
CLUTCH AND FLYWHEEL
PRESSURE PLATE
INTAKE MANIFOLD
EXHAUST MANIFOLD
TURBO
FUEL RAIL
THROTTLE BODY
DISTRIBUTOR
SPARK PLUGS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECTORS
OIL PAN
VALVE COVER
IGNITER
ECU
R32 GTR Skyline RB26DETT Complete $3850.00
R32 GTR Skyline RB26DETT Complete with no transmission $2550.00
CLUTCH AND FLYWHEEL
PRESSURE PLATE
INTAKE MANIFOLD
EXHAUST MANIFOLD
TURBO
FUEL RAIL
THROTTLE BODY
DISTRIBUTOR
SPARK PLUGS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECTORS
OIL PAN
VALVE COVER
IGNITER
ECU
300ZX VG30DE NON-TURBO 5 SPEED TRANSMISSION COMPLETE MOTOR SWAP $1150.00
300ZX VG30DETT TWIN TURBO 5 SPEED TRANSMISSION COMPLETE MOTOR SWAP $1850.00
300ZX VG30DETT TWIN TURBO AUTOMATIC TRANSMISSION COMPLETE MOTOR SWAP $1350.00
SOME PARTS ARE NOT INCLUDED IN THE NON-TURBO MOTOR SWAPS LISTED BELOW:
CLUTCH AND FLYWHEEL
PRESSURE PLATE
INTAKE MANIFOLD
EXHAUST MANIFOLD
TURBO
FUEL RAIL
THROTTLE BODY
DISTRIBUTOR
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECCTORS
SPARK PLUGS
OIL PAN
VALVE COVER
IGNITER
ECU
PM me if you have any concerns/questions/inquires
Thanks
TorontoJDM Team
