i have a ton of parts for them all!! lmk what you need!
A list would work a lot better then guessing what you have :thumbup
Yea what bike parts do you have?
I may needs SR20 partz.:ahh I could use some 12" wheels too if you have any.
You finally going to start putting that roach together again
I am looking for a S13 SOHC MAF? do you have one?
I still have a couple coil paks when you are ready to start your beast too… you probable thought I forgot about your good deads
a good rear subframe with a diff?
So what pitbike parts do you have? pics? a list of parts?
s13 or 14 subframe? deff have a welded or open diff, have tons of sr20 parts, pitbike? i have frames, suspension, engines everything call me 518 727 5858 Geoff
List out what pitbike parts you have and pics. I am not looking for anything spedific just if you have somthing I like.
S13 - this one has the rear steer in it and the subframe is definitely Fuxored.
put a reg rear end in that thing
Need rear shock for CRF50 and any and all of the rear brake assy. need brake pedeal rod, arm and stub rhat goes in hub. like i said everything. the only piece i have is the hub it’s self !!
