2GB HP PC2 5300 Memory with Heat Sinks (2x1GB)
2 - 1GB Modules of New HP Branded PC2 5300F with Black Heat Sinks
* NEW in Packaging from Hp. Dual Module Kit.
* This is for 2 sticks of 1 GB ram.
* 240 pin DIMM
* ECC 2Rx8
* DDR2 SDRAM
* CL5
DDR2 is the next generation of DDR memory. DDR2 memory features faster speeds, greater bandwidth, lower power consumption and enhanced thermal performance. Although DDR2 modules are the same physical dimension as DDR modules, the plug-in connector configuration is different and as such DDR2 modules are not compatible with PCs requiring DDR modules.
HP Memory 2GB 667MHz DDR2 PC5300 Registered ECC SDRAM DIMMS
(2 * 1GB Interleaved)
This is genuine HP Memory, Can be used in:
DL585 G2, DL385 G2/ DL365G1, BL465C, BL25P, BL20P
I bought the wrong memory I need DDR, so either trade for some DDR or video card or
$100 cash
They retail for $300
crap ECC ram…
