Im aquired a motor with some venom python injectors with a aem fuel rail, its off a B16 Head with a B20 Bottom, and one of the injectors are bad on them.
I dont know what rating on the venom python injectors are as there is no marking or stamping of anything on the injectors. if you can showl me how to find out that would be helpful to.
But its a all motor build, and i have no idea what is installed on the motor, except for the ovbious one like, AEM cam gears and Fuel Rail and Venom with no identification on the injectors.
Anyways i read up and they said i need at least 330cc+ injectors.
So that what im looking for because one of the injector is stuck open. so when the fuel pump is running its just spraying fuel into without even runing or starting.
it does have a 255 walbro fuel pump installed.
