i need some rear lca’s from a da integra. i also need rear springs. but i will consider a entire combo of top hats and struts if they will work for me.
I have EG rear suspension if you interested. Should bolt right up. 347-989-5028
i need a da setup. its about 1 to 1.5" longer or more travel than the eg. i am lifting a civic so i need all the travel i can get for cheap so i am going to use oem or oe stuff
My good friend is parting a da. Pm me exact parts needed and ill get you a price and when I can have the parts off for you.
pm sent
from a da i could use the front knuckles with brakes, rear lca’s with sway bar, rear strut assembly, may consider seats and brake booster and prop valve too if 40/40
I have everything you need if that other guy don’t work out. Plus a parts car you can take anything you want off of. Has real nice interior. Let me know
