parting out my 91’ hatch thats been sitting in the garage
the car is in pieces now, and everything is go
beige exterior, brown int, spilerless hatch w/ tint(no rust, other then hinch area)
5spd, non ABS, hicas, VLSD, 7 spoke wheels on low life kumho 712(205/55/15)
s13 ABS frt calipers w/ HP+(~70% life), HPS rear(~60% life)
almost 300k on chasiss(forgot exact, cause i messed up the cluster while i was playing w/ it
~6k on engine, KA24 DOHC, engine was rebuilt w/ oem spec parts, other then 0.15mm overbore pistons, wiseco 1.1mm head gasket, ARP head, rod studs, nismo thermostats, rotational assy balancing
Engine, 5spd trans, w/ ACT PP, exedy Stage 1 clutch disc - $400
KYB AGX + Eibach prokit(~2 yr old, w/ top mount bearing) -$200
hicas delete -$30
walbro 255 fuel pump - $50
HKS hi power 120mm tip catback(used for ~3 months) - $400
Nismo FPR(new) - $100
goodridge SS brake lines(BNIB) - $150
DeatschWerks 550cc injectors(BNIB, bought from bing) - $300
