94 s10 gas tank. Fairport
this will be at the curb come get it! 40 park circle drive 14450
came out of a running 94 v6 s10. pump, sending unit, wires, lines, all still attached. even has some gas in it!
http://images.craigslist.org/3n43k93lc5V25Q25R4abr90b5563fa8b912c2.jpg
http://images.craigslist.org/3m63o33l25P05X15R4abr70e23879f0801977.jpg
http://images.craigslist.org/3n03k63o35Y45V65Z3abr63c3f2c534a41a13.jpg
I also have a condenser, lines, and blower box from a 98 s10. not at same location but can meet up if you really want them
fml i need the filler neck sending unit and fuel pump… do you know if the arm on the sending unit works or is bent, im assuming all these fit on a 99 s10
No. 98+ stuff is different. The pump/sending unit attached differently to the tank and all of the hoses have different connections.
but you should still come take it and see if you can make it fit :slight_smile: I haven’t opened the tank at all so it should be fine and not bent
