ACT Clutch and Fidanza Flywheel, DC Sports Header - KA
I really want to sell this before I leave.
ACT clutch & Fidanza flywheel combo. very low mileage, 8K, installed last year. Pulled when we swapped to SR. Smooth engagement. Perfect for most NA setups or light turbo. 300.00
The clutch is the following: http://www.advancedclutch.com/produc...d_id=2281#2281
NX1-HDSS = heavy duty kit
The price of the clutch and flywheel alone are over 650!!!
http://www.gonrad.com/200809/dsc_0011.jpg
DC Sports KADE Header. Used for just under a year. Has the EGR port plugged but can be taken out if you wanna run it. Comes with 02 sensors. 175.00
http://www.gonrad.com/200809/img_2232.jpg
http://www.gonrad.com/200809/img_2231.jpg
PM if you are interested. I have the header here in Toronto, clutch and flywheel are still in windsor.
link doesn`t work and you said you took it out for sr swap so will this work on a s13 or just a s14 motor?is there a difference
Sorry.
Link is http://www.advancedclutch.com/1209079/0/0/0/1995_NISSAN_240SX_L4_2.4L_N_FI_(KA24DE).html
Its a performance street disc clutch with HD pressure plate. Will hold 267ft-lbs
Im almost positive it will work an ANY KADE engine meaning it will fit either S13 or S14.
Will the Fidanza work on sr20Det?
Its for a KA, so no.
ACT makes an SR20 application, but the item Pete is selling is KA only.
will u be in windsor any time soon to bring the clutch and flywheel back to toronto.
I will be in windsor the second week into FEB.
Headers are SOLD.
Clutch and flywheel could be in Toronto this weekend actually.
Clutch and flywheel are SOLD.
