The car is a red 1985 ae86 coupe GTS, mostly rust free (only on the pass rear quarter, but comes with a rust free one)… I bought the car when i was in high school… had huge plans for it (like all us 86’s owners) but life has caught up… shell is engine less but i have the gze…
prices are obo, im not sure if the prices are current, so your welcome to politely correct me… however i will not even respond to lowballers…
ae86 rolling shell w/ additional clean rear quarter (no sun roof) —$1000
20v individual throttle bodies w/ toyota atlantic carbon fiber TRD intake plenum —$500
velocity stacks —$120
modified ink trueno fiberglass fenders (BRAND NEW) —$250
nice size intercooler 18" x 5 3/4" x 2 3/8" —$200
HKS BOV —$175
HKS EVC, Electronic Boost Controller —$250
HKS Turbo Timer —$75
Sparco Sprint bucket with universal sparco sliders —$175
new front brake disks —$40
shortened strut casings —$30
TRD Japan front 8k springs (1 coil cut) —$100
86ers short shifter (i have two, need to be cleaned up) —$75/each
16v red findanza cam gears NIB —$300
t28 ball bearing turbo (from s15 sr20, wastegate welded) —$350
16v high rise equal length turbo manifold (external wastegate) —$250
(i think i have a gze wiring harness) —$150if i find it
brand new oem water pump —$100
brand new oem oil pump —$100
brand new oem clutch slave cylinder —$100
unorthodox racing crank pulley —$150
unorthodox racing flywheel NEW —$300
aw11 4agze long block (dissembled) —$2500
- block honed (slight over boar)
- acid cleaned
- crank, rods, pistons balanced
- stock forged rods
- stock forged crank
- JE Custom made pistons, 1mm over boar (went through hell and back for these pistons… basically, JE has a number in their books for 4age pistons because of me…)
- bottom end pre assembled
- full arp studs, nuts and bolts for vital parts
- ported and mild polished head
- valve job, new seats and seals
- complete oem gasket and seal set
- bluetop cams
- blue printed so far on assembly
- all machine work done at EC Auto Machining with receipts -
JDM 7mgte engine —$400
JDM 7mgte ecu —$100
7mgte fidanza flywheel —$175
im positive there is more in my back yard, lots of oem ae86 stuff, but i will find that as things start to sell…
Im not on here much so please dont PM me or expect a quick response in this thread… email me… gee_tee_eye@hotmail.com
parts are in Edmonton Alberta Canada… shipping at buyers expense…
