Asking Price: $175 OBO
Condition: USed but in proper working order
Will Ship?: Nope
Contact Info: PM me or e-mail me at jwoodrow91@hotmail.com
Description:
The AVC-D is A’PEXi’s lower end boost controller. It is an electronic controller but doesn’t have feedback. Just set the Duty Cycle on the Controller and tweak until you get the Boost you want and installs in less then an hour.
1 - The Three Boost area Settings are nice and allow any Boost you want Set at 3000, 5000, and 7000 RPM (based on Solenoid Duty Cycle 0-100%).
(Lights up with a soft Green glow, until the knobs are being used, Example if the car is @ 3000 rpm, the 3000 rpm knob glows Red and as it goes from 3000 to 5000 the 5000 then becomes Red).
2 - Has a feature which will limit the amount of Boost to the Speed you are traveling, for a launch when you don’t want to break traction in first gear this really helps when high Boost is set. (Has [2] pot controls on the rear “Time 0-30 seconds & Speed 20-200mph”. Turn all the way LEFT the SPD Knob on the front will have no function as it is turned off)
3 - Also has a Scramble Boost feature that allows the user to either add or subtract from the current boost level via a press of a button (Wired in Separately).
NOTE both the Speed Sensitive Boost Adjustment and Scramble Boost Feature may be turned off when not in use.
Unit comes complete with Control Unit, Boost Solenoid and un-cut Wiring Harness for both the Control Unit & Solenoid.
