I have a b16a I put in my 92 Teg mid summer. I probably havn’t put 500 miles on it since and would much rather have some cash. Can’t remember if I posted it up here before or not, kept wanting to but don’t think I ever got around to it.
Thing looked mint before I put it in. I need to keep the obd2 dist. the 450’s, the flywheel, the vtec solenoid, and the tps sensor. I can include stock obd0 dist. and injectors if you want. I also have an obd1 ls dist. if you want to clip a leg and use it. And the chipped flywheel pulley in the pics I had turned on a lathe so it was balanced.
It has great compression, you can come see it run and I’ll retest if you want the exact numbers. I’m asking $650, willing to sell off short block, or head separate also.
Pics before I put it in:
 therefore i dont need to play with myself.
