Blown sr20det redtop block + sr 5 speed transmission
hey I have a blown sr20det redtop block. #4 piston rings let go and I beleive spun a bearing. this can be rebuilt no problem. need to get rid of it asap. comes with oil pan, oil pump, and all internals. located in Ottawa, Can deliver to the nov 1st shannonville track day. $150
ps. also have an sr20det transmission $100. is missing a chunk from bellhousing, have the peice so it can be welded back togethor with a tig welder. also can deliver to nov 1st drift day
just to clarify for the son lowballers…this is the block only does not come with ecu, harness, injectors, head, turbo. short block only!!!
last call for driftops free delivery
hey
About the engine… motor mounts included? pulleys? anything else you can name is would be key. also about the tranny? what happen to it? why is there a chunk missing from it? lmao! how bad is the damage? also how well did it shift? oil changes?
Thanks
Sergei
