I had the ISIS line on my car for just over a year before the line literately blew. Cheap shit plastic with stainless wrapped over it. I then got a line made at Rush Hydraulics made out of good Areoquip parts. Rated to 3,300PSI. I also used new EARL’S performance fittings. Exact same as the ISIS fittings. The fitting to the power steering pump has the O-ring, important or it will leak. Reason for selling, I made two knowing I could save shipping and cost at the Rush hydraulics.
The line is made with reusable fittings, you can cut this line shorter if you choose. It can also be used with the 90° bends or without. This gives you the most amount of options depending on what your set up looks like.
$120 shipped.
