I bought from Rowe Photo as a replacement for my other camera while it was being repaired by Canon.
I have my old one back and don’t need this one anymore.
I bought this one on 8/14/2009, so i have only had it for 4 months.
It was bought used at Rowe Photo (the one on Mount Hope). It was brought in on a trade and thoroughly gone through by the guys at Rowe Photo.
It is in perfect working order.
It is only the body, a charger and the manuals/cds. No cables, No Battery, No CF Card.
I am asking $500 but I am very open to offers.
Email works best.
If you want to come by with a CF card and take some pictures with it then go home and inspect them, I am cool with that.
Info on the camera:
Product Features
- 10.1-megapixel CMOS sensor captures enough detail for photo-quality poster-size prints
- Large 3.0-inch LCD display with enhanced Live View and broadened color gamut
- 6.5 frame-per-second continuous shooting capability (for bursts of up to 75 Large/Fine JPEGs or 17 RAW images)
- sRAW mode; 35-zone metering system; integrated Self-Cleaning Sensor Unit
- Powered by BP-511A, BP-511, or BP-512 lithium-ion battery pack; stores images on CF cards
Technical Details
- Color: Black
- Type: Digital AF/AE SLR
- Recording medium: CF Card Type I and II and external media (USB v2.0 hard drive, via optional wireless file transmitter)
- Image format: 0.87 x 0.58 inches (APS-C size sensor)
- Compatible lenses: Canon EF, EF-S, TS-E, and MP-E
- Lens mount: Canon EF mount
- Lens focal length conversion factor: 1.6x
- Image sensor: High-sensitivity, high-resolution, single-plate CMOS
- Pixels: Approximately 10.10 megapixels
- Total pixels: Approximately 10.50 megapixels
- Aspect ratio: 3:2 (horizontal: vertical)
- Color filter system: RGB primary color filters
- Low-pass filter: Fixed position in front of CMOS sensor
- Recording format: DCF 2.0 (Exif 2.21); JPEG, RAW, and RAW+JPEG simultaneous recording possible; multiple options for recording images on memory card
- Image format: JPEG, RAW (Canon CR2)
- File size: JPEG/large: approximately 3.5 MB (3,888 x 2,592); JPEG/medium: approximately 2.1 MB (2,816 x 1,880); JPEG/small: approximatley 1.2 MB (1,936 x 1,288); RAW: approximately 12.4 MB (3,888 x 2,592); sRAW: approximately 7.1 MB (1,936 x 1,288)
- Folders: Automatically created by camera
- File numbering: Continuous, auto reset, manual reset
- Color space: Selectable between sRGB and Adobe RGB
- Interface: USB 2.0 high-speed mini-B port; NTSC/PAL for video output
- White balance settings: Auto, daylight, shade, cloudy, tungsten, white fluorescent light, flash, custom WB setting, user-set color temperature
- Auto white balance: Yes, taken from imaging sensor
- Personal white balance: White balance bracketing: 3 consecutive images written to CF card for each firing of shutter; up to +/- 3 levels in 1-step increments; white balance shift: blue/amber bias and/or magenta/green bias +/- up to 9 levels; manually set by user
- Viewfinder type: Eye-level SLR with solid glass pentaprism
- Coverage: Approximately 95 percent
- Magnification: 0.95x (-1 dpt with 50mm lens at infinity)
- Eyepoint: Approximately 22mm
- Dioptric adjustment correction: -3.0 to +1.0 diopter
- Mirror: Quick-return half mirror (transmission: reflection ratio of 40:60)
- Viewfinder information: AF (AF points, focus confirmation light), Exposure (shutter speed, aperture, ISO speed, AE lock, exposure level, spot metering circle, exposure warning), Flash (flash ready, flash exposure compensation, high-speed sync, FE lock, red-eye reduction light), Image (monochrome shooting, maximum burst, white balance correction, CF card information)
- Depth-of-field preview: Enabled with depth-of-field preview button; possible in Live View function
- Eyepiece shutter: None
- Autofocus type: TTL-CT-SIR AF-dedicated CMOS sensor
- AF points: 9 cross-type AF points, including center AF point; fully functional with f/5.6 or faster lenses
- AF working range: EV -0.5 to 18
- Focusing modes: Autofocus (One-Shot AF, Predictive AI Servo AF, AI Focus AF), manual
- AF point selection: Automatic, manual
- Selected AF point display: Superimposed red illumination in viewfinder; also visible on top or rear LCD panel when AF point select button is pressed
- AF-assist beam: Intermittent firing of built-in flash
- Metering modes: 35-zone TTL full-aperture metering: evaluative, partial, spot, center-weighted average
- Exposure control systems: Program AE (shiftable), shutter-priority AE, aperture-priority AE, auto depth-of-field AE (non-shiftable), full auto (non-shiftable), programmed image control modes, manual exposure, E-TTL II autoflash program AE
- ISO speed range: Equivalent to ISO 100 to 1,600 (in 1/3-stop or whole increments)
- Exposure compensation: +/- 3 stops in 1/3- or 1/2-half increments
- AE lock: Auto: applied in One-Shot AF mode with evaluative metering when focus is achieved; manual: by AE lock button in all metering modes
- Shutter type: Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled
- Shutter speeds: 1/8,000 to 30 seconds (1/3-stop increments); X-sync at 1/250 of a second
- Shutter release: Soft-touch electromagnetic
- Self-timer: 10-second and 2-second delay
- Remote control: Canon N3 type terminal
- Flash type: Auto pop up, retractable, built-in flash in pentaprism
- Guide number: 13/43
- Recycling time: Roughly 3 seconds
- Flash-ready indicator: In viewfinder
- Flash coverage: 17mm lens focal length
- Flash metering system: E-TTL II autoflash
- LCD monitor: 3-inch TFT color
- Pixels: Approximately 230,000
- Coverage: 100 percent
- Brightness control: 7 levels
- Image display format: Single image, 4-image index, 9-image index, jump, magnified zoom (approximately 1.5x to 10x), histogram, AF point display, auto rotate, rotate; live view: view image before shooting on LCD monitor; live histogram and live simulation of exposure level possible with C.Fn IV-7-1
- Highlight alert: In the single image display and info display, over-exposed highlight areas will blink
- Protection: Single or all images in memory card
- Erase: Single image, select images, all images in CF card or unprotected images
- Direct printing from camera: Yes, with Print/Share button
- Compatible printers: CP and SELPHY compact photo printers, PIXMA photo printers, and PictBridge-compatible printers (via USB cable, included with camera kit)
- Settings: Print quantity, style (image, paper size, paper type, printing effects, layout), trimming, tilt correction (compatibility varies, depending upon printer in use)
- Power source: Dedicated battery pack, AC adapter
- Number of shots: Approximately 1,100 images (normal shooting, no flash); approximately 800 images (50 percent flash use)
- Battery check: Automatic
- Item width: 5.7 inches
- Item height: 4.2 inches
- Item depth: 2.9 inches
- Item weight: 26.1 ounces
