Fidanza Billet Aluminum Flywheel 198581 for a 93-97 Camaro LT-1 with around 500 miles on it. You can buy replacement friction surfaces if it concerns you. A clutch spring let go and scrambled around inside scratching up a non important surface. Can be seen in the pictures but has no impact on performance or longevity. Will fit Chevrolet Camaro 1993 - 1997 5.7L LT-1 & Pontiac Firebird 1993 - 1997 5.7L LT-1 $250 OBO
(http://www.summitracing.com/parts/fiz-198581) -
Powermaster OEM-Style High-Torque Replacement Starters Part # 9200 Used on a stock 350 for less then 5k miles. $130 OBO
(http://www.summitracing.com/parts/pwm-9200) -
Mallory ignition 6-al spark box with built in rev limiter also comes with a owners manual and a secondary harness to hook up to a Chevy hei distributor to eliminate the spark control module and use the magnetic trigger and coil so you can have a rev limiter on your vehicle. $160 OBO
(http://www.summitracing.com/parts/maa-6853m/overview/) -
Summit Racing Street & Strip SFI - Approved Flexplate SUM-G100SFI $30 OBO
(http://www.summitracing.com/parts/sum-g100sfi)
