Chip Burner
Williams Programmer to re burn your oem chips.
$50
does this have software? and what applications will it allow you to use it on?
it burns chips for the ecu. comes with software to burn.
you need to create and tune your own files. this unit burns the files to the chip, than you insert the chip into the ecu.
to edit files you will need rom edit , tuner pro etc
