b series hydro clutch ACT 6 puck unsprung. unknown milage. as is $50
rear disk swap off a 94-95 GSR $100
gsr trans side torque mount$30
gsr shift linkage. had a small kink in the middle of it. i put some heat on it and straitened it out. good to go now $40
5 spd swap froma 92-95 civic. comes with everything pictured plus the center hump,shift linkage,and pedal assembly$135
everything is located at 26554
