Im selling my complete Kenwood Excelon Car audio as I need money to move. This is by far one of the cleanest and loudest systems I have ever heard.
Picture taking from a cell phone, Ill list all the specs and price at the bottom
SPECS
KFC-XW1300DVC - Kenwood eXcelon 13"
13" Tornado- Type Woofer
2,000 Watts Peak Power
1,000W RMS Power
82dB Sensitivity
Dual Conex Dampers
2-Piece Cast Aluminium Frame
30Hz - 1KHz Frequency Response
3Ω + 3Ω Impedance
2-Piece Magnet (10.9lb)
9.7" Mounting Depth
Built-in 25A Protection Fuse
Long Throw Dual Vented Voice Coils
Vented Pole Piece with Internal Heat Sink Fins
1" Wide, Extra Thick Rubber Surround & Gasket
Banana Plug-Compatible, Screw-Lock Design Speaker Connector
More Plates For Stronger Energy Density
Higher Voltage Under Load
Tightly Packed Cells
Superior Heat & Vibration Resistance
Kenwood KAC-X812D High Performance Mono Power Amplifier
Class D Amplifier Circuit
A.M.S. (Amplifier Management System)
Built in Parametric EQ Control
AMP Information Display (Voltage,Current, Temperature, Cooling Fan Speed)
Built-in Variable Low-pass Filter
Built-in Infrasonic Filter
1Ω Load Capability
Gold Plated Input/Output Terminals
Line Output Terminals (RCA) for Extension
2-Speed Cooling Fan
Detachable Aluminum Dress Plate
Power Specifications - Full Range Channels
RMS Power @ 4 ohms 533 watts x 1 channel
RMS Power @ 2 ohms 919 watts x 1 channel
RMS Power @ 1 ohm 1016 watts x 1 channel
Bridged RMS Power Not Bridgeable
Peak Power Output 1600 watts
Amplifier Specifications
Number of Channels 1 - Mono
Total RMS Power Output 1016 watts
Minimum Impedance Unbridged 1 ohms
Minimum Impedance Bridged N/A
THD at Rated RMS Power 1.0%
Speaker Level Inputs Yes
Preamp Outputs Yes
Built-in Crossover N/A
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 50 - 200 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio 100 dB
Channel Separation N/A
Bass Boost N/A
Bass/Gain Remote No
Fan Cooled Yes
Kenwood KFC-X1300P
5-1/4" 2-way Component System
Power Handling:
Peak: 360 watts per set / 180 watts each side
RMS: 90 watts per set / 45 watts each side
Impedance: 4 ohms
5-1/4" Woofer Carbon-PP Hybrid with Butyl Rubber Surround
1" Soft Dome Swivel Tweeter with Protection Circuit
3-Point Tweeter Attenuator
Cast Aluminum Basket
-18dB/oct Crossover Network
Frequency Response: 40 Hz - 30 kHz
Sensitivity: 91 dB
Kenwood KAC-X522
High Performance 2-channel Power Amplifier
RMS Power: 165 watts x 2 chan. @ 4 ohms
RMS Bridged Power: 505 watts @ 4 ohms
AMP Information Display (Voltage, Current, Temperature, Cooling Fan Speed)
Low-pass/High-pass Filter
2-Speed Cooling Fan
Kenwood KVT-614
WMA Playback: Yes
Satellite Radio Ready: Yes
RMS Power Output: 4x22 Watts
Remote Control: Yes
Preamp Voltage: 5 volts
Subwoofer Preamp Outputs: Yes
MP3 playback: Yes
Maximum Power: 4x50 Watts
HD Radio: Optional
DIN: 1
Detachable Face: No
Changer Control: Yes
CD-R/CD-RW Compatible: Yes
CD Text: Yes
Built-in EQ: Yes
Bluetooth Ready: yes
Audio/Video Inputs: 1
Front USB Input: No
Rear USB Input: Yes
Audio/Video Outputs: 1
Kinetik HC 800
AGM Technology
Sealed Non-Spillable Design
Mount In Any Position
Ultra Low ESR
Weight: 26 lbs.
Ah: 36
Amps: 950
Dimensions: 7.6" x 5" x 6"
All wires from JL audio, I have all recipets to prove so you will have Kenwoods 2 year warranty.I also have all boxs, and all the work inculding the custom built to spec subwoofer box was done at Radioactive in Burlington
I spent over $3225.00
Price is only $2000.00 the Kenwood KVT-614 DVD player sells for $700+ alone. This really is an amazing deal with recipets to give you warrantys and piece of mind.
Please P/m if you have any questions Thanks
