SOLD SOLD SOLD!!!
Hi i have a cummins onan P6500 generator for sale. This has barely been used (maybe 2 tanks) and is in excellent condition! It is a 5000wt generator and i have run my fridge, air conditioner, TV, cable box, cable modem, wireless router, lamps, phone charger and microwave lol. Its a beast but the only bad thing is i don’t have the wheel kit for it ($30) and its pretty heavy. It has electric start but i never bought a battery for it and it uses a basic riding mower battery. I had no problem just using the pull start cause it fires up right away. I posted a link below so you can see the price, specs, and features.
PRICE $400 firm
PM,
FEATURES:
Electric Start (Recoil Backup)
•Start your generator with the touch of a button
•Uses a 12 volt, 14L-A2 battery (not included)
Cast Iron Sleeve
•Durable material helps to extend engine life span
Volt-Meter
•Accurate and continuous voltage reading
Fuel Efficient
•Reliable 13 HP OHV engine runs up to 9 hours
SPECS:
Model Number:P6500 Manufacturer:Cummins Onan Made in USA:NoEngine Brand:Unknown Starting System:12-Volt Button Start w/ Recoil HP/CC:13 HP Consumer Engine Warranty:2 Years Commercial Engine Warranty:Not Available Engine RPM:3600 RPM Low Oil Alert:Yes Cast Iron Sleeve:YesProduct Specs Voltage120/240 Single-Phase Frequency:60 Hertz Alternator:Unknown Auto Voltage Regulation:No Fuel TypeGasoline Rated Amps:21 Amps @ 240 Volts (Single Phase) Portability Kit:Sold Separately Tank Size:6.5 Gallons Run Time (50% Load):9 Hours Fuel Tank Material:Metal Fuel Gauge:No Decibel Rating @ 7m:76 db(A) Idle Control:No Hour Meter:No Voltage Meter:Yes Lifting Eye:No Battery:Not Included (525 CCA)Overview Weight:185 Lbs. (83.92 kilograms) Dimensions:26.8L x 21.3W x 21.7H
(68.07 x 54.10 x 55.12 cm)
