D16a6 block (p29s, arp) + D16z6 motor
i was going to build an all motor single cam but changed my mind. i bought the block from toolow69 like 2 months ago, never used it. like 20k on rebuild.
d16a6 block, P29 pistons, ARP head studs, ARP rod bolts
sold
I also just pulled the motor out of my civic. Its a d16z6 out of a 95 ex. has 180k…
head- sold
block- sold
intake mani- $20
exhaust mani- $15
clutch- $10
z6 head wont bolt up to a y8 right ?
y8 block? it will
hmm…
lmk…i saw your hatch at the lot last night,
looks good
thanks…
Yea I may scoop this up from you .
cool just call or text me if/when you want it. 2570095
That a6 with the z6 would be a nasty setup… for a D anyways.
yea im still debating whether to hold on to it. i just dont have the money to do what i want… they can put out good power tho
bump
You got the z6 ecu?
negative… i put another z6 in it so im using it
I may be interested the pistons. do you have the P28 pistons? or will the P29’s work in a D16Z6? I’m rebuilding mine and the pistons broke today so I need to find cheap replacements quick. Thanks.
well the p29s will work but they will raise the compression. so youll need a tune…but i have a z6 block with p28’s for $50.
So you got a Z6 ecu kicking around? I’d pick up the head and ECU to throw on the Crx if you got it.
i dont have an ecu…
best offer
bump… lowered prices, need this all gone.
Whats wrong w/the z6 bottom? Is the crank and block still good?
not exactly sure, it should be still good. i pulled it out and now its just sitting in my gpas garage… if youre interested i can look it over.
