Deamon Tools Help?
hi. what i am attempting to accomplish is this.
i want to install Farcry on a computer at work. i found a program called daemon tools that you can supposedly copy the game to this and play it without a disc.
has anyone here heard of this or even how this process works?
thanks for your help.
~ron
yep, start daemon, then click on it on the taskbar and choose the image file to mount and then open up my computer and u shall see another drive with the mounted file.
i do not quite unserstand how you work it still, a little more help is needed i think.
i have not even installed the game yet. please if you could telll me all steps i need to do to do this.
you need to have a copy of the disk on the computers hard drive
this is often in .iso format and sometimes called and iso
You take this image and mount it in daemon tools fooling the computer into thinking that, that disk has been inserted into a drive on the computer
play farcry at work?? where do you work?
Abercrombie & Fitch. and i am a store manager so i can pretty much play what want.
ok so i have disc in there… how do i copy it? or should i just run and install it first?
or just make it an iso then try to run / install it when its mounted?
run and install
then you use a program to create an iso for later use
all daemon tools does it make it so you never need the disc
ok so run it… then i make it into an iso file by using? isobuster?
WinISO, or equivalent program will work… I will put a copy on my FTP site when I get to work later today if you want. Stay tuned.
yes that would be great.! when do you work?
ok, since most of you are guessing on how to use DT from some of the posts here.
dont forget to set the emulation settings on the taskbar, the game will not work if safedisk, securom, or any other protection is enabled, DT will emulate this making the clone seem like its an actual cd in the drive.
wait a minute. Am i missing something here? You have the game already, you just want to be able to play it without having the cd in the drive? If that’s the case, you don’t need Daemon Tools or any .iso making or anything. You just need a no-cd crack.
LOL
was that directed at me?
I may be a little vague but i use it almost daily for gaming
Edit-After reading my posts i doubt it was (i forgot what i said really)
yeah tahts what i want to do for a majority of the games i have on here… i hate chaning the disc every 3 seconds if i want to play a different game… i would like to just be able to play it without the use of discs… how do i find a “no-cd crack” and is this easier?
http://www.rubicant5x.com/winiso/
download both, instructions are in the info.txt file…
http://m0001.gamecopyworld.com/games/pc_far_cry.shtml
1.)Download appropriate file.
2.)Follow instructions.
3.)Win
No-CD crack or fix is what you are looking for
What he said. Daemon tools is a CD-Drive emulator, it allows you to use CD-images with out actaully burning a CD.
