I’m aimlessly wandering around my house tonight, minding my own business, when I notice a bulb is out in the chandelier above my kitchen table. Being Johnny On The Spot though I am, I have more bulbs on hand so I grab one, turn off the chandelier, swap it out, turn the chandelier back on, and the light is back on again.
So I walk over to the trash can to throw away the bulb when I hear ZZZZZT and swing my head around just in time to see a small shower of sparks come raining down from the chandelier, followed the all the lights in the chandelier going out and a small smoke cloud rise up from the newly installed bulb.
:wtf:
So I pull out the new bulb. Sure enough, it’s cooked:
But ALL the lights on the chandelier are out… I go check the breaker in the basement and nothing tripped. Back upstairs. I look at the dimmer switch on the wall. The switch has a little glowing bulb in it telling me that the switch is still seeing 120 volts. (If I was smart I would have noticed that before I went to check the breaker.)
I grabbed one of the “good” bulbs out of the chandelier and threw it into another light and it lights right up. So the bulbs are good but they’re not getting juice in the chandelier. Hmm… The switch is seeing 120VAC but the chandelier isn’t.
I pull the switch out. Someone who owned the house before I did was an even bigger hack than myself. Multiple wires are connected without wire nuts. The switch’s neutral falls out easily. Not the cause of my problem, but something to fix while I’m in there.
I grab my multimeter and check for continuity across the full travel of the dimmer. No continuity. I disassemble the switch to find the reason that the circuit breaker didn’t trip: The switch didn’t give it a chance to:
OK cool, that’s why the chandelier isn’t seeing power, but that’s not the cause of my problem. That open circuit is a result of a current spike, not the cause of a current spike. Better keep digging. If I don’t positively identify the reason that I let the smoke out of my light bulb then there’s a chance that my house will burn down from an electrical fire soon. Not a risk I’m willing to take.
Back to the chandelier. I pull the socket out to find a nasty corroded mess.
The wire insulation was extremely brittle and falling off, so when I changed the bulb I must have put the last straw on the proverbial camel’s back:
Good. Positive identification of the cause: The insulation fell off of the old nasty wires, shorting Line to Neutral and spiking the bulb with current before the switch melted, opening the circuit again. Now I just have to decide if I want to deal with the pain in the ass of pulling new wire through the chandelier or just buying a new chandelier. I better think this one through:
