You can PM me, but texting me might be a faster way to contact me. 716-697-2049
EG6 Parts:
EG6 P30 Intake Manifold (No sensors included, just the manifold and throttlebody) $45
EG6 Fuse Box (Some fuses are missing, does not come with a cover) $30
EG6 “T” Bracket (perfect for B-series swaps into EG chassis’) $25
EG6 Drivers Side Post Mount, Drivers Side Engine Mount, and Transmission Mount $15 each $35 for all
EG6 B16 Hydro Trans Diff (Is in good working order, only removed for a LSD install) SOLD
EG6 Header (Sandblasted top half, bottom half has small dents in it) SOLD
CRX Parts
CRX Converter (Works great and is not clogged up, one of the studs is missing on the midpipe side) SOLD
CRX Pedal Assembly (has all sensors, its only missing the piece on the prake pedal that touches the sensor to turn the brake lights on/off) $40
CRX Clutch Cable (no parts missing, had no problem with it while it was in use) $25
CRX Trottle Cable $10, Speedo Cable $10, and Hatch/Gas Door Cables $25
EF8 Air Box (pulled this out of a CRX front clip up in canada, I now have no need for it) $45
CRX Intake Arm with K&N Filter Arm $25
DA Parts
DA Half Shaft SOLD
DA LS Rods and Pistons (just has some carbon buildup on them, comes with all of the caps, never separated) 45</b>   <b>Random #!+
GSR Brake Booster (Pulled this from a CRX shell I bought) $45
OBD1 LS Dizzy $40
Integra Bumper Lights (may not be available, Im going to give these to a friend of mine if he needs them but figured I would post them up anyways) $30
Blox 2.5’’ Velocity Stack $25 All other items pictured OBO
B-Series Flywheel Cover $15
Harness’
DOHC ZC Harness UNCUT $100 obo
EG6 Engine Harness (no vtec plug or injector plugs), DA Engine Harness, CRX Behind Dash Interior Harness, and CRX Tucked Headlight harness’ (only good for use of the plugs)
ALL OF THESE SHOWN HAVE SOMETHING CUT OUT OF THEM, I am willing to sell in “as is” condition for best reasonable offer. Also willing to part out specific plugs that you may need. If you need more specific pictures of a plug or any questions about either one of these harness’ please feel free to contact me.
EG6
DA
CRX Interior
CRX Headlight Harness’
