I am proud to accounce that I will be offering EM Racing products to all of you at great prices that you have come to expect from Touge Tuning. The way this will work is pricing will be based upon the total number of products ordered. The more I order the better pricing I can offer to you all. I will leave the list open for a few weeks or until I reach the maximum discount level and then the order will be placed. Prices listed include all taxes, shipping to you is extra but wont cost very much.
Tiers are based opon total order quantity not just of that specific piece but of all orders.
Tier 1: Under 10 total pieces ordered
Tier 2: 10-24 total pieces ordered
Tier 3: 25-49 total pieces ordered
Tier 4: 50+ total pieces ordered
Contact Info:
Chris Richardson
Sales@TougeTuning.com
(MSN) TougeTuning@hotmail.com
C-Pillar Bars
By tying the c-pillars together, the structural rigidity of the vehicle’s chassis is reinforced, preventing the pillars from flexing under hard cornering.
- Approximate installation time: 5 mins
- Aircraft quality 6061
- T6 aluminum
- Significantly improves handling
- Bar stock disconnects in seconds: No Tools Required!
Fitments:
-88-91 CRX
-88-91 Civic HB*
-92-95 Civic HB**
-92-95 Civic 2dr/4dr
-96-00 HB
-92-96 Prelude**
-97-02 Prelude
-90-93 Integra 2dr
-94-01 Integra 2drTier 1: $191
Tier 2: $175
Tier 3: $158
Tier 4: $142-90-93 240sx HB***
Tier 1: $146
Tier 2: $137
Tier 3: $121
Tier 4: $108
Note: backseat and seatbelts may be left intact, but presence of backseat passengers is prohibited while bar is in place. Failure to comply may result in serious or fatal injury. Off road and race use only.
- Plastic surrounding seat belt mount must be trimmed for proper fitment (89-91 civic hatch only)
** Panel requires minor cutting for proper fitment for 92-95 Honda Civic HB.
***Models with black seatbelt box only. Sealtbelt assembly must be removed. No quick release option.
Rear Strut Brace
Ties the two rear opposing strut towers together as a single solid unit for increased chassis rigidtity and improved overall handling. Integrated on each strut brace mount are the brackets for the triangulated bars which make upgrading simple and painless.
- Approximate installation time: 10 mins
- Sturdy one piece brackets
- Straight across design: No 90 degree bends
- Adjustable pre-load to maintain desired camber settings
Fitments:
-88-91 CRX
-88-91 Civic HB
-92-95 Civic HB
-96-00 Civic HB
-96-00 Civic 2dr/4dr
-92-97 Del Sol
-90-93 Integra 2dr
-94-01 Integra 2dr
-94-01 Integra 4drTier 1: $249
Tier 2: $233
Tier 3: $209
Tier 4: $200-02+ Acura RSX
Tier 1: $146
Tier 2: $137
Tier 3: $121
Tier 4: $108-03+ Lancer Evo VIII
Tier 1: $232
Tier 2: $218
Tier 3: $196
Tier 4: $188-90-93 240sx HB
Tier 1: $232
Tier 2: $218
Tier 3: $196
Tier 4: $188
Note: Some paneling may require minor cutting for proper fitment
Trunk Floor Bar
A must for all cars from street to all out competition. This bar takes the twist and roll out of the sheet metal by connecting two solid points in the trunk floor.
- Utilizes factory tapped holes
- Adjustable ends makes installation simple
- Rod ends withstand over 12,000 lbs. of radial load
Fitments:
-92-95 Civic HB
-96-00 Civic HB
-93-97 Del Sol
-94-01 Integra 2dr
-94-01 Integra 4drTier 1: $155
Tier 2: $146
Tier 3: $132
Tier 4: $118-02+ Acura RSX
Tier 1: $146
Tier 2: $137
Tier 3: $121
Tier 1: $146
Tier 2: $137
Tier 3: $121
Tier 4: $108
Triangulated C-Pillar Bar:
This addition triangulates the c-pillar tie bar and the rear strut tower brace, completing the four sided structure (see explanation page for details).
- First triangulated pillar bar in the market for the Integra and Civic
- Improvement is undeniable: You will FEEL a difference!
- Triangulated for maximum rigidity
Fitments:
-88-91 CRX
-88-91 Civic HB
-92-95 Civic HB
-96-00 Civic HB
-90-93 Integra 2dr
-94-01 Integra 2drTier 1: $155
Tier 2: $146
Tier 3: $132
Tier 4: $118-90-93 240sx HB
Tier 1: $146
Tier 2: $137
Tier 3: $121
Tier 4: $108
Note: Must be used in conjunction with rear strut tower bar and the c-pillar bar. Each sold separately. Rear passenger side seat must be folded forward for bar to fit in place for some models.
- Passenger side seatbelt can not be retained for 96-00 Honda Civic HB
Triangulated Trunk Bar
This addition triangulates the trunk floor bar and the rear strut tower brace, completing the four sided structure (see explanation page for details).
- First triangulated trunk bar in the market for the Integra and Civic
Fitments:
-92-95 Civic HB
-96-00 Civic HB
-93-97 Del Sol
-94-01 Integra 2dr
-94-01 Integra 4drTier 1: $149
Tier 2: $139
Tier 3: $122
Tier 4: $108-02+ Acura RSX
Tier 1: $146
Tier 2: $137
Tier 3: $121
Tier 1: $140
Tier 2: $130
Tier 3: $114
Tier 4: $100
Note: Must be used in conjunction with rear strut tower bar and trunk floor bar. each sold separately.
Trunk Wall Brace:
For all you DC2 owners, this bar installs where the OEM Type-R brace sits, but with a little added style. Made from high stiffness to weight ratio 6061-T6 aluminum, this upgrade prevents the brittle trunk wall from flexing.
- Approximate installation time: 30 mins
- Available in brushed aluminum
- Includes all necessary hardware
- Improves regular and hard driving conditions
Fitments:
-94-01 Integra 2drTier 1: $142
Tier 2: $129
Tier 3: $115
Tier 4: $101
Note: Plastic panel requires minor cutting for proper fitment. Some drilling is also required.
Rear Lower Tie Bar
Fitments:
-92-95 Civic HB
-96-00 Civic HB
-93-97 Del Sol
-94-01 Integra 2dr
-94-01 Integra 4drTier 1: $142
Tier 2: $129
Tier 3: $115
Tier 4: $101
DRIVE Road Race Master Cylinder Brace
Drive Road Race Products are designed for the hardcore enthusiast in mind. Clearly far superior in design and quality, this product was designed by Drive engineers to withstand the abuse put forth by extreme drivers.The Master Cylinder Brace, made of 6061-T6 Aluminum billet, mounts onto the inboard side of the shock tower housing and prevents the brake master cylinder from moving forward (caused by flex in the firewall and brake booster) when excessive pressure is applied to the brakes under hard driving conditions, such as road racing and autocross. The overall result is a greatly improved brake feel and sensitivity, therefore reducing brake fade…even for everyday street use!! The brace comes with two M6 (10mm head) threaded bolts.
- Aircraft quality 6061-T6 aluminum
- Improves pedal feel
- Quick and easy installation
Fitments:
-92-95 Civic
-96-00 Civic
-94-01 IntegraTier 1: $109
Tier 2: $99
Tier 3: $88
