engine diff?
is there any diff between the 93-97 and the 98-01 altima engines or bays?
Bays: No, they’re both the same…
Engines: Generally no, emissions and such may be different but if you have the ECU to match its ok. However the 2000 and 2001 engine has 155 hp over the 150.
i did’nt think there was a diff,cause i was looking apexi, and they make a short ram for the 2nd gen altima, and i was wondering if it would fit?
should, and wasnt it Injen? Personally just grab an Ebay one and get a decent air filter for the end…
I’'m not sure if they have this for your application, but Injen actually makes a kit that allows you to have the parts to set your car up with eather a Short Ram or Cold air, so that you can run the short ram in the winter and a cold air setup in the summer for a little more power when your less likely to dirty up the filter. It might be worth looking into. I recommend it to a lot of honda people looking into this kind of thing. Just a thought. If your not worried about the filter I agree that finding a pipe on ebay and then just getting a good quality filter for the end could save you a lot of money.
Injen makes the short ram, and HotShot Makes the CAI intake (pretty much have to order from a dealer). The Hot shot can be modded to short ram (has removable CAI section)…
But in the end, do you want a name or do you want a decent setup?
i want a good setup with a great filter, sorry i ment injen, thats why if i go custom i am thinking about getting a aem dry filter.
or the stillen, or jwt filter setup
there are just KN filters on a Maf adapter…
