JDM HONDA B20B 96-98 OBD2 ENGINE ONLY
ITEM LINK: http://www.torontojdm.com/cart.php?target=product&product_id=4520&category_id=101
$499.99
INCLUDES:
ENGINE BLOCK
HEAD
INTAKE MANIFOLD
EXHAUST MANIFOLD
CRANKSHAFT PULLEY
THROTTLE BODY
INJECTORS
FUEL RAIL
VALVE COVER
SPARK PLUG WIRES
SPARK PLUGS
OIL PAN
OIL CAP
DIP STICK
1996-1998 SPECS
• NON-VTEC
• FOUND IN: USDM AND JDM HONDA CR-V, JDM ORTHIA, STEPWGN, S-MX
• DISPLACEMENT: 1,973 CC (120.4 CU IN)
• POWER: 126 HP (94 KW)) @ 5400 RPM
• TORQUE: 133 FT•LBF (180 N•M) @ 4300 RPM
• ROD LENGTH: 137 MM (5.4 IN)
• COMPRESSION: 8.8:1 OR 9.2:1
• BORE: 84 MM (3.3 IN)
• STROKE: 89 MM (3.5 IN)
• REDLINE: 6300 RPM
JDM HONDA B20B 99-01 OBD2 ENGINE ONLY
ITEM LINK: http://www.torontojdm.com/cart.php?target=product&product_id=4626&category_id=101
$699.99
INCLUDES:
ENGINE BLOCK
HEAD
INTAKE MANIFOLD
EXHAUST MANIFOLD
CRANKSHAFT PULLEY
THROTTLE BODY
INJECTORS
FUEL RAIL
VALVE COVER
SPARK PLUG WIRES
SPARK PLUGS
OIL PAN
OIL CAP
DIP STICK
1999 - 2001 SPECS
• NON-VTEC
• FOUND IN: USDM CRV AS A B20Z, CR-V AND HONDA ORTHIA AS A B20B
• POWER: 146 HP (109 KW) @ 6200 RPM
• TORQUE: 133 LB•FT (180 N•M) @ 4500 RPM
• COMPRESSION: 9.6:1
• REDLINE: 6700 RPM
*OTHER PARTS AVAILABLE FOR SEVERAL MAKES AND MODELS. FEEL FREE TO CONTACT US FOR PRICING FOR YOUR SPECIFIC NEEDS / VEHICLE
