I’m searching for the smallest, yet most efficient engine oil cooler possible. it needs to be thin to fit in front of my radiator. i ran into two styles im leaning towards, and im wondering which extracts more heat…:
stacked bar and plate:
or
coiled tubular:
i’d perfer to avoid fan cooled to save a couple inches depth
note: these aren’t necessarily the ones i’d use, just an example of the cooler type
anyone know of any with a thermostat, thats not expensive?
Im sure the difference between the two isn’t that much but look to see if the manufacturer posted the thermal efficiency rating. If its that important and you can’t find it online, call them and ask.
The setrab unit is amazing. I have used it on a few cars. It will drop the temps in no time if you use the thermostat. if you don’t it will never heatup.
BAr and Plate … without a doubt … ALL of my AOD cars run one for the trans … only way to keep them alive… I did a test about 4 years ago on one of my stangs … and the stacked plate setup was 30* cooler than a shitty tube setup … this was tested in bumper to bumper traffic in the middle of summer
