holset te turbocharger single inlet.
if you do your research its similar to gt 30 in flow capabilitiers, its used and good for rebuilt(as any used turbo should be rebuilt) , wheels are in good shape no play. $80
This turbo t3 flanged? 4 or 5 bolt exhaust side? Do you know the specs of it?
the line is to feed ur turbo its universal so just needs proper fitting for your turbo’s oil inlet etc.
and for return all i have is regular t3 return flange and 2 fittings one to go into the return flange, and other for hose to clamp in as far as i know its 4 an size.
i have no spec’s just punch in holset hx35w its oem turbo doge usses on all their cummins engines. this is the smallest t3 they make single inlet.
If you do you research you will know what this turbo is all about.
i am selling it as a core cuz housing is good and wheels are good the rest i dunno.
