f.s. 94 gsr complete head w/ intake/tb/distributor/harness
i have a 94 gsr head. head is clean, no warp. using a straight edge most i can get under it at any spot is .010-- or it is ready to bolt on as is. service limit is .05. cam caps are clean too. comes complete w/ cams, intake, throttle body, fuel rail w/ injectors, wiring harness, and distributor.
the head has 122k on it. the bottom end is junk-- tossed a rod bearing and i got rid of the block a while back.
will split up if all the parts are spoken for. had it sold but original person flaked.
Sailor, PM member watacanga…he needs a head for the block he just got from me.
pm’d, vtec solenoid??? obdI just what i need
vtec solenoid is there. think i even have the stock head studs. valve cover is here too.
basically, take a complete head and unbolt it off the engine.
what are you looking to get out of it??
PM me with your lowest price please. thanks
pm me a price too
If you part it out…I’ll grab the throttle body, Sails
