got to get this stuff out of my life…and my dinning room
Genuine GARRETT t04e turbo .58 ar hot side. I polished the compressor side and forgot the ar. Its a 50 trim, ceramic coated hot side,only 1500 kilometers on it, very very minimal shaft play. $475 obo
ca18det t4 flanged top mount turbo manifold bought it off ebay (not ss autocrap) but similar pollished aluminum, good welds, runners dont touch. with gaskets and bolts. SOLD!!
ca18det stock intake manifold, doesn’t include injector rail or fuel rail. it has the throttle body. $100
ca18det stock injectors great condition. $30 or will include with manifold for $15
ca18det stock turbo manifold, no turbo, just the manifold, good condition.$50
ca18det stock camshafts ,no gears,mint, no nicks or scratches.$80
stock silvia/240 rear seats with mounts no rips,tears or blemishes.$60
ca18det stock con rods and pistons, rods are mint, pistons are good, could probably use new rings…if you are rebuilding you should do it anyway. $80
prices seem reasonable to me, if you want to combine things I can make a deal. Thanks
