F.S.: Flat bed trailer
I am selling my trailer. The following are the specs.
  • the deck is 98" wide between fenders, inside to inside
  • the deck is 192" long, lined with pressure treated lumber
  • pole tongue trailer, the tongue is 48" long
  • has a weight distributing pole tongue adaptor so you can use a WD type hitch, tows better if you’ve ever towed anything
  • tandom axle, each axle is rated at 3500 pounds
  • 7000#'s GVWR
  • 6 wire round harness hook up
  • Electric brakes from front axle
  • Electric break away device, but I haven’t hooked it up yet, too lazy
  • rams are 66" long by 10" wide
  • stake pockets all around
  • LED rear lights
  • safety chain included
  • cab mounted brake controller included
  • has convertable coupler, it currently is set up to use a 2-5/16" hitch ball, but you can also get yourself an adaptor and use a pintle ring with it
  • 4 load rings welded on each corner of the trailer
  • 3 sets of tie down straps included
  • spare rim included
Tows real nice and straight. Stake sides included (think of it as a wooden fence around your trailer) so you can use it as a box trailer. The heaviest load I ever put on it was a 93 Ford Exploder 4X4.
Asking price $3000.00
Located in Bayview and Shepard
cmatt(at)rogers(dot)com
mchum(at)bonfigliolicanada(dot)com
Pics will be hard for me to post since I don’t have a camera
