Sold…
pics and model number on receiver, i’ll try to make my parents interested in it for the game room
i want second dibs. I’m moving in less than two weeks, and need something for my TV.
reciever model number VSX-305
would you seperate the speakers from the receiver and sub?
i already have a VSX-516 i could give them since i resently got an 816
Id rather not, I just want to sell it and be done with it. Make me an offer on the whole deal, then re-sell it after you swap out what you need.
That’s a pretty old model, not even 5.1. I’ll start the bidding at $70. (Identical set is selling on craigslist for $40)
x2
i could use the speakers. but it is an older model.
jenn, want my VSX-516?
Well, I mean Im not tryin to get rich here…I just wasnt sure what it was worth… $85 takes everything!
how much for the sub?
$85 and it comes with everything else
how much? no speakers right?
let’s negotiate… $75
damn u matt…wish u would have had this shit when we made are deal cuz we could have worked out a deal ccuz i would have def took this
How about that rear sway bar plus $35 for it?
25 + swaybar and i’ll get the swaybar today while i’m up there for you
give me a call today ![]()
Ok, if it comes with the endlinks too…and can you see if you can get the brackets that mount to the frame also?
ya i’ll give u the endlinks, the brackets i modified cuz the setup that came with it was a pinch plate setup and it always slide off the frame rail & i would be running the sway bar hooked just to ones side then it would make the truck pull real bad till i got under it and reinstalled the pinch plates …so we took a piece of like 6"x3"x1/4" steel and tachd it to the frame rail and used the endlinks to remove it when needed…it made it soooooo much stiffer & better back there i wish i did it that way from the beginning
Oh ok, so I just need to weld a piece of metal to the frame and drill a hole in it for the end link? I have to go to work in a few mins… you wanna meet up tommorrow to do the deal?
yup that it and angle the pc a little to drop it down to keep the sway bar level or gert longer endlinks …
sure that sounds good i have money in hand and the sway bar is sitting here on my porch ![]()
