Hello,
I am selling the parts from my RB20DET motor,i bought this motor from (JDI) Japan Motor Import In Montreal in feb 2009 which i was going to put in my 280z datsun, plans change a bit. The motor was in great condition, never install just sat in my garage. There are a few up grades i made like flywheel, injector, manifold with welded flange for external wastegate. You can PM or call (647) 207-8318 or email thunderkitz@hotmail.com.
Thanks
Rb20det Transmission $300
Gtr injector great condition $180.00
Manual boost controller $25.00
Rb20det igniter pack good condition $60.00
Rb20det Injectors $60
Rb20det 6x coil pack good condition $150.00
Rb20det Camshafts $100
Rb20det Head complete except cams great condition with new intake gasket $200
Rb20det Block complete great condition $250
Alternator $50
Starter $50
Valve covers $50
Valley cover $20
Timing belt cover $20
Intake manifold $50
Rb20det Exhaust manifold/welded flange with new 38mm trial wastegate with two springs rate 1bar & 7psi $180.00
Crank pulley $20
Rb20det used clutch with pressure plate & and 3 puck disc $80.00
Rb20det flywheel lighten 7lbs and balance by machine shop $180.00
Rb20det cam angle sensor $70.00
Rb20det intake piping make a offer
Rb20det line’s & hose make a offer
Rb20det maf $50.00
Rb20det stainless steel catless cat $50.00
