F.S. Rims and Tires
I got a set of BF Goodridge KDW mounted on a set of Nissan Sentra SE rims. Here are the specs:
205-50/16
Well over 80% of tread left
No camber wear
Located in North York
Rims are drilled for 4 X 114.5 ONLY, not 4 X 100
16 inches in diameter by 6.5 inches wide.
Colour is silver.
You can have the above package for 700 dollars. Ready to go now
I got a set of WHITE 5 Zigen Fireball rims, they are a couple years old but very well taken care of so there aren’t any smash marks. Here are the specs
The tires on the rims now have no life left
16" in diameter by 7 inches wide
WHITE in colour
Comes WITH center caps
Comes WITH hub centric rings (if Jackson can find it)
Drilled for DUAL bolt pattern (4 X 100 and 4 X 114.5)
42 mm offset
The above rims can be had for 600 dollars. Ready to go now
OR you can have my KDW PLUS Jackson’s Fireballs for 1200 mounted and balanced, in which case I’ll fork all the mounting and dis-mounting bills.
NO LOW-BALLING PLEASE but since this is a great forum I wouldn’t expect anybody to be doing so.
Please call me at 416-567-8520, I don’t use the computer much during the day
Matt
Thanks
