Condition: Used
Will Ship?: Yes, at buyer expense
Contact Info: Send PM.
S13 SR20DET Air filter HKS w/ coupler & MAF adapter, MAF 100$
Blow off valve, unknown brand … pshhh like new 100$
S13 SR20DET ECU from 1991 Silvia redtop 200$
Turbosmart Manual boost controller “Boost Tee” part # TS-0101-1010 80$
S13 SR20DET Cam angle sensor. 140$
T25 turbocharger w/ stock ex. Manifold, dump pipe … some shaft play 200
S13 sidemount I/C w/ duct ( welded diverter valve port ) 60$
S14 stock Fuel pump, from CDM 1995 240sx w/ KA24DE 40$
S13 rear left LCA (1X) 60$ / S13 tension rods w/o bushing (2X) 20$ / S14 traction arm (2X) 20$ / S14 tension rod (1X) 20$
R32 front knukkles w/hubs 40$
S14 front brake calipers (pair) from CDM s14 240sx 60$
S13 SR20DET flywheel, needs refacing 60$
S14 KA24DE MAF from CDM 240sx 60$
S13 SR20DET stock Dump pipe w/ Welded EGR port (3 in stock) 10$ each
T25 Turbocharger from S13SR blown seals 80$ / S13 SR20DET ex. Manifold 40$
S13 SR20DET full air conditioning system (exept evap) 100$
S14 side skirt / rear bumper Vertex knock off 500$ fits like a glove :bigup:
S13 SR rad 40$ / S14 KA rad 40$
S13 SR20DET transmission (2 in stock) 200$ each
Salbelt Torino 2in. 3 pt. Harnesses. 40$ for both
S13 Steering rack w/ Tien inner tie rod (6mm spacers), Megan racing tie rod ends. Hicas rack, shorter ratio than non-hicas 200$
S13 VLSD form 1991 Silvia 200$
S13 SR20DET Alu cold pipe, use w/ side mount I/C 80$
S14 HKS Hiper D full coilover set 800$
American Racing Rebel (same as Motegi touge) 2x 18/9 +12 2x 18/10 +30 w/ General Tire exclaim UHP 225/40 235/40 & 4x 235/40 toyo proxes 4 1500$
S13 SR20DET Fuel injectors 370cc (8 in stock) 20$ each
SR/KA stock shifter 20$
S14 KA24DET crank sensor on top of trans. bell housing 20$
S13 SR/KA coolant sensors 20$
Unpictured stuff :
SR/KA S13/S14 Cosmo short shifter ---- 80$ picture
S13/S14 SR20DET Denso/Sard 550cc long nose injectors w/ collars 500$ picture
SR/KA stock belt driven rad fan (3 in stock) 10$ each.
SR/KA S13/14 semi-solid engine mount 80$ shippied picture
