Does anyone have any idea how I can get me some fog lights for the 2008 Altima 2.5S 4cylinder?
I have a Sedan and not a coupe which is making it almost imposible to find after market.
Thanks
dealer, but they will rape you or try a body shop!!!
Hey Bud
I have gone to every dealer in my area and then some but I am still having no luck and that is why I wanted to see if anyone on here could help.
Thanks for trying
why do you want to go aftermarket? just get OEM fog’s from ebay and install it. if your car is prewired then its plug and play
Agreed!
just get OEM ones, better fitment, easier to install!
I would try ebay…
I dont know if its like the 06 where you have to change the factory stalk and if you have the harness on top of the bumper but i just got some wires and made my own harness and tapped it into the parklight wire.
if his car is prewired for fog (like mine was) then you have to change the factory stalk to the one with fog lights opt. every easy to change the stalk takes less then 5min.
but if car is not prewired then you would have to get you own harness / switch etc etc which is too much work.
Thanks and I am aware off that as well
I saw the ones on E-bay and the kits come with the wire lights and the switch but they are for the coupe and I’m told they will not work by the dealer
